Zmdv 2006.torrent - no seeders now!
Maybe, or perhaps the CD you burned from it is bad. You can use the md5sum included in the download to check both the CD and the ISO file. Just do "md5sum /dev/cdrom" and see if it returns the same hash as in the md5 file.Maybe it's the iso file downloaded with bitorrent corrupted?
I have check the md5sum and it's the sameJust do "md5sum /dev/cdrom
