Hello all,
I am running, sorry I try to install and run zoneminder on debian sarge.
What I did was the installation of the ffmpeg stuff from ffmpeg cvs.
Then I made the ZM
#./configure
which find everythink ok.
and after that
I tried the # make:
Here is the output and I have no idea on how to solve that correctlly:
# make
make all-recursive
make[1]: Entering directory `/usr/local/src/ZoneMinder-1.22.1'
Making all in src
make[2]: Entering directory `/usr/local/src/ZoneMinder-1.22.1/src'
g++ -g -O2 -L/usr/lib -L/usr/lib/mysql -o zmc zmc.o zm.o zm_db.o zm_config.o zm_coord.o zm_box.o zm_poly. o zm_image.o zm_event.o zm_zone.o zm_camera.o zm_local_camera.o zm_remote_camera.o zm_file_camera.o zm_monitor .o zm_user.o zm_mpeg.o zm_jpeg.o zm_regexp.o zm_signal.o zm_buffer.o zm_debug.o -lavformat -lavcodec -lavutil -lpcre -lcrypto -lmysqlclient -ldl -lz -ljpeg
/usr/local/lib/libavutil.a(mathematics.o)(.rodata+0x0):/usr/local/src/ffmpeg/libavutil/mathematics.c:50: multi ple definition of `ff_sqrt_tab'
/usr/lib/libavcodec.a(utils.o)(.rodata+0x0): first defined here
/usr/local/lib/libavutil.a(mathematics.o)(.rodata+0x80):/usr/local/src/ffmpeg/libavutil/mathematics.c:68: mult iple definition of `ff_log2_tab'
/usr/lib/libavcodec.a(utils.o)(.rodata+0x80): first defined here
/usr/local/lib/libavutil.a(mathematics.o)(.text+0x0): In function `av_rescale_rnd':
/usr/local/src/ffmpeg/libavutil/mathematics.c:50: multiple definition of `av_rescale_rnd'
/usr/lib/libavcodec.a(utils.o)(.text+0x1c80): first defined here
/usr/bin/ld: Warning: size of symbol `av_rescale_rnd' changed from 1090 in /usr/lib/libavcodec.a(utils.o) to 9 81 in /usr/lib/libavcodec.a(utils.o)
/usr/local/lib/libavutil.a(mathematics.o)(.text+0x3e0): In function `ff_gcd':
/usr/local/src/ffmpeg/libavutil/mathematics.c:45: multiple definition of `ff_gcd'
/usr/lib/libavcodec.a(utils.o)(.text+0x1070): first defined here
/usr/local/lib/libavutil.a(mathematics.o)(.text+0x440): In function `av_rescale':
/usr/local/src/ffmpeg/libavutil/mathematics.c:102: multiple definition of `av_rescale'
/usr/lib/libavcodec.a(utils.o)(.text+0x20d0): first defined here
/usr/bin/ld: Warning: size of symbol `av_rescale' changed from 1012 in /usr/lib/libavcodec.a(utils.o) to 65 in /usr/lib/libavcodec.a(utils.o)
/usr/lib/libavcodec.a(dtsdec.o)(.text+0x33d): In function `dts_decode_frame':
: undefined reference to `dts_frame'
/usr/lib/libavcodec.a(dtsdec.o)(.text+0x395): In function `dts_decode_frame':
: undefined reference to `dts_blocks_num'
/usr/lib/libavcodec.a(dtsdec.o)(.text+0x3bf): In function `dts_decode_frame':
: undefined reference to `dts_block'
/usr/lib/libavcodec.a(dtsdec.o)(.text+0x3fd): In function `dts_decode_frame':
: undefined reference to `dts_samples'
/usr/lib/libavcodec.a(dtsdec.o)(.text+0x485): In function `dts_decode_frame':
: undefined reference to `dts_syncinfo'
/usr/lib/libavcodec.a(dtsdec.o)(.text+0x51e): In function `dts_decode_init':
: undefined reference to `dts_init'
collect2: ld returned 1 exit status
It seems to me that I have multiple definitions within the libavutils , BUT I dont know how to repaire that ?
Can anyone give me a hint how to clean this up ?
regards
Multiple Definitions in libavutil during make of ZM on debia
- zoneminder
- Site Admin
- Contact:
If I had to guess I would say that maybe you installed a new version of ffmpeg which has libavcodec, libavformat and libavutil and then an older one which does not have libavutil but has the definitions in the other library. However you still have the libavutil library file from the other version present. Does that sound plausible?
Phil
You are right, BUT who runs ZM on debian ?
Hello Phil,
yes you are right. But I have no clue how to find which I can delete. I will try to fix the make files of zoneminder that they use just the manual installed ffmpeg sources and not the debian version.
I am almost sure thats just a version problem.
I will try to build the zm manually from THE manual installed ffmpeg. I tell you how far I come
If there are debian sarge users outside somewhere, maybe somebody can post how he got the ZM package to work on the latest sarge version.
CIAO Wolfram
PS: What I dont get is why the hell the ffmpeg maintainers did not update the debian sarge repository to the newest version.
Many debian people are having these problems, also for other sw packages than zm.
The zm debian package what is supposed to be on one of the networks posted herin is not anymore correct and even worth its outdated for the current debian sarge version. Maybe somebody can put a hint somewhere on the zm page.
CIAO Wolfram
wolfram
- zoneminder
- Site Admin
- Contact:
ffmeg installation on debian wih zm solved
Hi Phil,
yes the manual compile of ffmpeg did the trick to solve the avutil problem I had.
Now I will go the rest of the way to zm working...
Phil, I discover it takes less and less time to install zm, once you know what i sneeded.
Maybe I will write a little debian zm install addendum...
Cheers Wolfram
PS: Yes you are right regarding the ffmpeg people. Even though I cannot really understand why.
It should be no problem to run some scripts over night to build the package , once the scripts are created.
And there is A (!!!) packet. but OLD.
Cheers Wolfram
wolfram
- zoneminder
- Site Admin
- Contact:
ffmpeg on debian for zm how to on debian
Hello all Pre-Debian Users
For those who had a similar problem again a more descriptive info what I did to solve the ffmpeg problem.
(please read the complete post first)
the trick is, do NOT use the ffmpeg debian package or any prebuild package what you might find on the web. The ffmpeg people DO NOT !!! provide any package for debian as far as I know. Any package you might find is outdated or does NOT match with your specific installation. Thats my experience.
This means for installing on DEBIAN:
You have to manually build the ffmpeg libs which is in special the libavutils.
so
1. get the latest CVS version of ffmpeg
2. compile and build the package.
3. tell zm to use the new build lib and where it is.
1. run this comand : svn checkout svn://svn.mplayerhq.hu/ffmpeg/trunk ffmpeg
be sure that your firewall or router supports the routing of svn ports
see here a list of port numbers for subversion
http://en.wikipedia.org/wiki/List_of_TC ... rt_numbers
Put the repository output into /usr/local/src
2. Run the linux commands configure make make install
3. Tell the ZM configure script to use a special ffmpeg
the option when you run the ./configure script is
–with-ffmpeg=<path to ffmpeg root> which is wheer you have build the ffmpeg package
That should work.
I dont remeber the exact order I installed all this, but at the end this was the way I got it to work under debian.
Regards Wolfram
_________________
wolfram
so
That should work.
Regards Wolfram
_________________
wolfram
wolfram
