Motion JPEG Camera (Linksys WVC54GC)
Greetings, fellow users and esteemed developers.
I was curious to learn if anyone else happens to be using the WVC54GC ethernet/wireless video camera from Linksys - or, more specifically, using it with success.
Before trying this particular device, I did some searching and reading to determine that ZoneMinder does, indeed, support Motion JPEG.
The device supports, as I understand it, two HTTP paths: /img/mjpeg.cgi and /img/video.asf.
Setting up a monitor to pull from either of these does not seem to work so well, however.
I recently updated from the 1.21.3 version of the live CD (many thanks to Ross Melin), which works beautifully for my other camera - a DLINK that provides simple, static JPEG files.
Would anyone have any tips as to how a monitor would be set up properly for this MJPEG camera?
Just Noticed: From the Logs
zmc's run attempts generate this error in the system log:
"Unrecognised content type: application/octet-stream"
Please read:
http://www.zoneminder.com/forums/viewto ... highlight=
This was for the WVC54G - Not sure what difference your extra C makes in the model number, but from your post, I'd guess not much.
My conclusion after MUCH work trying to get this camera working is that: It doesn't.
It can be hacked to supply mjpeg (what zoneminder wants), except the output it produces isn't standard and neither works in ZM or Firefox (which handles mjpeg fine). It does produce MPEG4 (with the audio stream) but that's no use to ZM, and it's many other restrictions relegate it firmly to "pretty paperweight".
I've owned quite a few ip cameras, and this was by far the worst of them all. Crap build quality, crap lens, crap sensor, crap software, bugger all features, vastly underpowered (only one output stream - even the most basic Axis cam supports 20), NO support, Internet Explorer ONLY (ActiveX wrapper for the, again, non-standard MPEG4 stream)
The only thing that worked as advertised was the wireless-G link. Sorry for the bad news.
(Disclaimer: There is a change some guru has done a better firmware for this cam (it's open-sourced) but I couldn't find it.
RE: WVC54GC
Thank you for your reply.
I went through that posting, to see if it would get me as far as vague, partial functionality, but it looks as though Linksys has changed the CGI in this firmware, so that that trick does not work any more.
I will see if I can send it back.
- tech_fixer
Re: Grabbing Still JPEG
I can't find a way to grab simple JPEG images from the camera. I seem to be stuck with ASF or (apparently broken or somehow "special") MJPEG.
I managed to achieve pulling single frame JPGs off this web-cam as input to Zoneminder.
If I cron job it I manage to pull about 4 -5 frames every minute without overloading the Linux box too much. Not perhaps idea for motion detection (to put it mildy!) but it does give me at least a picture "stream" from an IP web-cam that is otherwise, as far as I can see, unusable as an input to Zoneminder.
Using mplayer, I do the following.dagummace wrote:How did you get to those individual jpeg's? By URL?
- execute a script using a cron scheduled task
the script logs on to the web-cam
retrieves a single frame image from Linksys WVC54G using mplayer
copies the jpg image file to a Linux file-structure location
configure ZoneMinder to use the "File" option to access the .jpg file
It's slow, it's clunky, it's far from ideal, but it works.
Which came first, the tree or the driveway?pdown85 wrote:If you look at my web-site http://www.coulterfamily.org.uk in the Navigation panel under MyWebCam you'll find the set up. There is an example of the captured image
Mathew
Congrats are really due elsewhere (http://majordomo.squawk.com/njs/blog/20 ... nksys.html): I just re-used/adapted the suggested method.Flash_ wrote:pdown, congrats on finding something useful for this crappy thing
Do you mind posting your scripts to get the jpgs?
The key line that does all the work is:
mplayer -nortc -nojoystick -prefer-ipv4 -nolirc -nocache -user USER -passwd PASSWD -frames 1 -vo jpeg http://your.cam.ip.addr/img/video.asf
mplayer -nortc -nojoystick -prefer-ipv4 -nolirc -nocache -user USER -passwd PASSWD -frames 1 -vo jpeg -vf scale=320:240 http://your.cam.ip.addr/img/video.asf
The script and all my installation notes, etc for mplayer and ZoneMinder are available on a link from my web-site as noted earlier.
Re: Motion JPEG Camera (Linksys WVC54GC)
I'm replying to this old thread in case anyone else stumbles across it looking for the solution to using these old cameras.
http://<ipaddress>/img/mjpeg.cgi?Speed=x
I use 15 for x
from this link
http://www.linksysinfo.org/index.php?th ... eam.12602/
I use 15 for x
from this link
Old thread, but for those interested, I got this working with firmware V1.21:
To switch the camera into MJPG mode:
http://camIP/adm/file.cgi?h_v_mode=jpeg&todo=save
Then access the (non-compliant?/funny) MJPEG stream:
http://camIP/img/mjpeg.cgi?Speed=x
where x seems to be the framerate.
For Motion users, apply the WVC200 patch, and access the stream as
mjpg://camIP:80/img/mjpeg.cgi?Speed=x
[ Not tested, but I would think to get the MPEG4 stream again you would do:
http://camIP/adm/file.cgi?h_v_mode=mpeg&todo=save ]
