I've upped the buffer size, i've changed it back to system default (yes, i've rebooted between them).
i have two network cameras, Panasonic BL-C10A's.
My zmc_m# processes keep dying more and more frequently since i upgraded from 1.22.0 to 1.22.1, with the following messages:
May 9 07:25:14 ogtzeta zmc_m2[10255]: ERR [Found unsupported content type '']
May 9 07:25:14 ogtzeta zmdc[4889]: ERR ['zmc -m 2' exited abnormally, exit status 255]
Both cameras are set to 'modetect', although the problem occurs whether the cams are set to 'modetect' or 'monitor'
I've tried the following trying to alleviate this problem:
1) Turned on and off the Network/Regular Expression option (used to work fine with it off)
2) Turned on and off the "Farm Out Analysis" option (had been working fine with this on)
Buffering is set as follow:
ImageBufferCount 36 28
WarmupCount 1 1
PreEventCount 9 6
PostEventCount 9 8
AlarmFrameCount 1 1
SectionLength 600 600
FrameSkip 0 0
MaxFPS 5.00 3.00
AlarmMaxFPS 6.00 4.00
Frame Id Alarm Frame Time Stamp Time Delta Score
1 No 07:25:11 -2.00 0
2 No 07:25:11 -1.67 0
3 No 07:25:12 -1.31 0
4 No 07:25:12 -0.98 0
5 No 07:25:12 -0.65 0
6 No 07:25:13 -0.28 0
7 Yes 17:00:00 9,999,999.99 2
Hopefully that's enough information to go on. Any help would be mucho appreciated...
--David
