hi all... sorry for the upper case title... but this is really very important...
http://www.openh323.org/ . openh323 is a library with protocol to make easier build
teleconference applications... just like the excellent gnomemeeting (www.gnomemeeting.org) and netmeeting compatible... it is really a piece of art.. i think this is the solution for zoneminder to stream VARIOUS FRAMES (its sometimes 5 times faster than other streamings methods) WITH AUDIO. its not an file format to archive, just like jpeg, but is a way to make it on the network. CISCO uses a similar protocol for their CISCO VOiP Routers..
i really think it will be great
ITS WRITTEN IN CPP
regards
Victor diago
PS : have you looked the webcdwriter ?
NEW VIDEO PROTOCOL --- PHILIP, LOOK THIS
- victor_diago
- Contact:
