zoneminder couldn't catch the remote camera... need help...
roc212
Post by roc212 »
I am new to Zoneminder. My zoneminder could work normally in the local mode, but couldn't work in the remote mode.
There is the /var/log/messages digests about "err":
May 16 10:22:01 localhost zmc_m1[2879]: WAR [Unable to use netcam regexps as not compiled with libpcre]
May 16 10:22:01 localhost zmc_m1[2879]: ERR [Invalid response status 210359044: Not Found]
May 16 10:22:09 localhost zmc_m1[2879]: WAR [Unable to use netcam regexps as not compiled with libpcre]
May 16 10:22:10 localhost zmc_m1[2879]: ERR [Invalid response status 210359044: Not Found]
May 16 10:22:21 localhost zmc_dwebcam[2936]: ERR [Failed to open video device /root/webcam: Permission denied]
May 16 10:22:21 localhost zmdc[2855]: ERR ['zmc -d /root/webcam' crashed, exit status 255]
May 16 10:22:21 localhost zmwatch[2907]: ERR [Can't get shared memory id '7a6d2002', 2: No such file or directory]
May 16 10:22:21 localhost zmwatch[2907]: INF [Restarting capture daemon for local-test, shared memory not valid]
May 16 10:22:32 localhost zmc_dwebcam[2947]: ERR [Failed to open video device /root/webcam: Permission denied]
May 16 10:22:32 localhost zmdc[2855]: ERR ['zmc -d /root/webcam' crashed, exit status 255]
May 16 10:22:32 localhost zmc_m1[2879]: WAR [Unable to use netcam regexps as not compiled with libpcre]
May 16 10:22:33 localhost zmc_m1[2879]: ERR [Invalid response status 210359044: Not Found]
Thank you very much! :)
roc
mg
Post by mg »
What distro do you have? libpcre is missing...
yum install pcre
yum install pcre-devel
Should be done before running ./configure
roc212
Post by roc212 »
yum install pcre
Thank you! :P
distro: FC4
Is libpcre neccessary for ZoneMinder?
And are all of errors caused by libpcre?
ps: the local mode can work fine.
roc
zoneminder
Site Admin
Post by zoneminder »
No. If you do not use regecps for the netcams then you do not need libpcre.a, though sometimes this doesn't always work with some cams.
Phil
