Login fails, returns to login screen
Hi Guys,
Zonemider from the latest live cd havs been running fine. for a few weeks now, but to day i can no longer login.
i've looked at the log files and don't see anything odd.
ZM is still running as i an getting e-mail i just cant login anymore.
Where should i be looking for errors.
Regards
Paul
Regards
Paul
your log files for mandrake are located under/var/log id check your messages log there first just after you have tried to login. Also check that you have cookies enabled on the browser you are trying to log in with
James Wilson
If i tail -f messages i see events from zm, but no errors or message with reguard to the login.
looking in the http access log i get this.
192.168.1.115 - - [18/May/2006:15:54:16 -0700] "POST /zm/index.php HTTP/1.1" 200 1064 "http://192.168.1.27/zm/index.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.3) Gecko/20060426 Firefox/1.5.0.3"
192.168.1.115 - - [18/May/2006:15:54:16 -0700] "GET /zm/zm_html_styles.css HTTP/1.1" 304 - "http://192.168.1.27/zm/index.php" "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.3) Gecko/20060426 Firefox/1.5.0.3"
using ethereal i captured this lot
Host: 192.168.1.27
User-Agent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.3) Gecko/20060426 Firefox/1.5.0.3
Accept: text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
Accept-Language: en-us,en;q=0.5
Accept-Encoding: gzip,deflate
Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive: 300
Connection: keep-alive
Referer: http://192.168.1.27/zm/index.php
Cookie: format=html; cookies=1; ZMSESSID=50b05a8c414338678ba0fd0006f2af5f
Content-Type: application/x-www-form-urlencoded
Content-Length: 59
action=login&view=postlogin&username=admin&password=adminHTTP/1.1 200 OK
Date: Thu, 18 May 2006 22:55:44 GMT
Server: Apache-AdvancedExtranetServer/2.0.50 (Mandrakelinux/7.2.101mdk) PHP/4.3.8
X-Powered-By: PHP/4.3.8
Set-Cookie: ZMSESSID=50b05a8c414338678ba0fd0006f2af5f; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
Content-Length: 1064
Keep-Alive: timeout=15, max=100
Connection: Keep-Alive
Content-Type: text/html
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<title>ZM - Login</title>
<link rel="stylesheet" href="zm_html_styles.css" type="text/css">
<script type="text/javascript">
window.resizeTo( 720, 480 );
</script>
</head>
<body>
<table align="center" border="0" cellspacing="2" cellpadding="2" width="96%">
<form name="login_form" method="post" action="/zm/index.php">
<input type="hidden" name="action" value="login">
<input type="hidden" name="view" value="postlogin">
<tr><td colspan="2" class="smallhead" align="center">ZoneMinder Login</td></tr>
<tr><td width="50%" class="text" align="right">Username</td><td width="50%" align="left" class="text"><input type="text" class="form" name="username" value="admin" size="12"></tr>
<tr><td width="50%" class="text" align="right">Password</td><td width="50%" align="left" class="text"><input type="password" class="form" name="password" value="" size="12"></tr>
<tr><td colspan="2" align="center"><input type="submit" value="Login" class="form"></td></tr>
</form>
</table>
</body>
</html>
Host: 192.168.1.27
Accept: text/css,*/*;q=0.1
Keep-Alive: 300
If-Modified-Since: Fri, 15 Jul 2005 03:58:48 GMT
If-None-Match: "d44264-1237-445c0e00"
Cache-Control: max-age=0
HTTP/1.1 304 Not Modified
Date: Thu, 18 May 2006 22:55:45 GMT
Keep-Alive: timeout=15, max=99
ETag: "d44264-1237-445c0e00"
So does this shed any light on it.
Regards
Paul
Host: 192.168.1.27
Keep-Alive: 300
Content-Length: 59
Pragma: no-cache
<html>
<head>
</script>
</head>
<body>
</form>
</table>
</body>
</html>
Host: 192.168.1.27
Keep-Alive: 300
Regards
Paul
nope not for me mate lol. I would have thought there would be an error somewhere!, Are you on the live cd as in 1.21.3/4 or the newer mandrive based install cd?
James Wilson
i noticed on your etherreal grab that you sent admin/admin as login details, has it chnaged all passwords or just the admin one?
Id check your db for consistency too but i would have hought youd get other issues first!
I cant see that it simply forgot it!!??
James Wilson
I assumed you had thats why i didnt comment before lol
So it had changed both passwords but not the user names?
Have you checked the db is ok?
James Wilson
should check the dbmysqlcheck --all-databases --auto-repair -ppassword -u user
James Wilson
Re: Login fails, returns to login screen
+ 1 Herewheelbarrow wrote:Hi Guys,
I was lucky running ZM 1.24.2 @ Ubuntu server 10.10 x86 with 55Gb HDD on the old hardware for about 5 days.
An hour ago I was able to login via web console.
And a hour after I tried to login again, and it brings me back to login screen again.
Ok, investigating the problem gave the following:
:/var/log$ tail syslog
Dec 5 16:31:39 MyHostNameHere zma_m2[4658]: ERR [Can't open events/2/10/12/05/16/14/12/16534-capture.jpg: No space left on device]
Dec 5 16:31:39 MyHostNameHere zma_m1[4654]: ERR [Can't open events/1/10/12/05/16/14/11/16564-capture.jpg: No space left on device]
Dec 5 16:31:40 MyHostNameHere zma_m2[4658]: ERR [Can't open events/2/10/12/05/16/14/12/16535-capture.jpg: No space left on device]
:/var/log$ cat messages
Dec 5 16:14:15 MyHostNameHere zmaudit[4662]: INF [Database event '2/1484' does not exist in filesystem]
Dec 5 16:14:15 MyHostNameHere zmaudit[4662]: INF [deleting]
Dec 5 16:14:15 MyHostNameHere zmaudit[4662]: INF [Database event '2/1487' does not exist in filesystem]
:/var/log/apache2$ cat error.log | grep "No space left"
[Sun Dec 05 15:13:27 2010] [error] [client 192.168.1.3] socket_bind( ) failed: No space left on device, referer: http://192.168.1.1/zm/index.php?view=watch&mid=1
[Sun Dec 05 15:13:27 2010] [error] [client 192.168.1.3] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 18,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_bind( ) failed: No space left on device',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.1/zm/index.php?view=watch&mid=1
$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/sda1 55G 38G 14G 74% /
none 748M 260K 748M 1% /dev
none 754M 0 754M 0% /dev/shm
none 754M 52K 754M 1% /var/run
none 754M 0 754M 0% /var/lock
Anyway, I managed to free some space:
sudo rm /tmp/*.log
sudo rm /var/log/*.gz
sudo apt-get clean
sudo apt-get autoremove
$ df /var -h
$ df /tmp -h
IT WORKED!!!
I was able to login to the console again!
Some recent event was missing with 'null/null' value.
May be, php errors about no disk space, were prevenitng the http session to start.
Ok, if it is the FREE SPACE issue, questions are:
1. How do I properly configure the partitions for the ZM prod installation?
2. How to set up debugging / logging level?
3. How to set up rotation and tell ZM to use defined amount of disk space?
Hope, this info help people, who stuck on logon screen.
Dear ALL, please help on remaining questions!
Thanks,
dima_the_chief
UPDATE:dima_the_chieff wrote:+ 1 Herewheelbarrow wrote:Hi Guys,
IT WORKED!!!
Yes, It Worked but not for a long time
looking more deeply in log files:
$ tail /var/log/apache2/error.log
[Sun Dec 05 18:42:01 2010] [error] [client 192.168.1.5] PHP Warning: session_start(): open(/var/lib/php5/sess_0qpsln2ut7otallbst4jbnnkf7, O_RDWR) failed: No space left on device (28) in /usr/share/zoneminder/index.php on line 77
[Sun Dec 05 18:42:01 2010] [error] [client 192.168.1.5] PHP Warning: Unknown: open(/var/lib/php5/sess_0qpsln2ut7otallbst4jbnnkf7, O_RDWR) failed: No space left on device (28) in Unknown on line 0
[Sun Dec 05 18:42:01 2010] [error] [client 192.168.1.5] PHP Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php5) in Unknown on line 0
[Sun Dec 05 18:42:10 2010] [error] [client 192.168.1.5] PHP Warning: session_start(): open(/var/lib/php5/sess_0qpsln2ut7otallbst4jbnnkf7, O_RDWR) failed: No space left on device (28) in /usr/share/zoneminder/index.php on line 77, referer: http://192.168.1.1/zm/index.php
[Sun Dec 05 18:42:10 2010] [error] [client 192.168.1.5] PHP Warning: Unknown: open(/var/lib/php5/sess_0qpsln2ut7otallbst4jbnnkf7, O_RDWR) failed: No space left on device (28) in Unknown on line 0, referer: http://192.168.1.1/zm/index.php
[Sun Dec 05 18:42:10 2010] [error] [client 192.168.1.5] PHP Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php5) in Unknown on line 0, referer: http://192.168.1.1/zm/index.php
[Sun Dec 05 18:42:11 2010] [error] [client 192.168.1.5] PHP Warning: session_start(): open(/var/lib/php5/sess_0qpsln2ut7otallbst4jbnnkf7, O_RDWR) failed: No space left on device (28) in /usr/share/zoneminder/index.php on line 77
[Sun Dec 05 18:42:11 2010] [error] [client 192.168.1.5] PHP Warning: Unknown: open(/var/lib/php5/sess_0qpsln2ut7otallbst4jbnnkf7, O_RDWR) failed: No space left on device (28) in Unknown on line 0
[Sun Dec 05 18:42:11 2010] [error] [client 192.168.1.5] PHP Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php5) in Unknown on line 0
[Sun Dec 05 18:42:33 2010] [error] [client 95.52.210.96] Invalid URI in request u\xc8g\x1a?;\xb8\x1e\xd6\xe1\xe5\xd4)\x17Z{\x11\xd8)D \xe6R\xe8\xbf\x1b\xaci\xd4H\x8b\x91\x19-\xec\xecD\xd2_\xda\xbc\xe4O\x907\x8d\xd2S
:/var/lib$ ls -l
drwx-wx-wt 2 root root 4096 2010-12-05 17:09 php5
:/var/lib$ sudo chmod 777 php5
:/var/lib$ ls -l
drwxrwxrwx 2 root root 4096 2010-12-05 17:09 php5
Is this yet another PHP5 problem?
dima_the_chief
Make sure your not out of inodes.. You can easily have plenty of free disk blocks and be out of inodes, and the result is the same.
check with "df -i"
Bill
check with "df -i"
Bill
dima_the_chieff wrote:UPDATE:dima_the_chieff wrote:+ 1 Herewheelbarrow wrote:Hi Guys,
IT WORKED!!!
looking more deeply in log files:Ok, now, let's look at it:Code: Select all
$ tail /var/log/apache2/error.log [Sun Dec 05 18:42:01 2010] [error] [client 192.168.1.5] PHP Warning: session_start(): open(/var/lib/php5/sess_0qpsln2ut7otallbst4jbnnkf7, O_RDWR) failed: No space left on device (28) in /usr/share/zoneminder/index.php on line 77 [Sun Dec 05 18:42:01 2010] [error] [client 192.168.1.5] PHP Warning: Unknown: open(/var/lib/php5/sess_0qpsln2ut7otallbst4jbnnkf7, O_RDWR) failed: No space left on device (28) in Unknown on line 0 [Sun Dec 05 18:42:01 2010] [error] [client 192.168.1.5] PHP Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php5) in Unknown on line 0 [Sun Dec 05 18:42:10 2010] [error] [client 192.168.1.5] PHP Warning: session_start(): open(/var/lib/php5/sess_0qpsln2ut7otallbst4jbnnkf7, O_RDWR) failed: No space left on device (28) in /usr/share/zoneminder/index.php on line 77, referer: http://192.168.1.1/zm/index.php [Sun Dec 05 18:42:10 2010] [error] [client 192.168.1.5] PHP Warning: Unknown: open(/var/lib/php5/sess_0qpsln2ut7otallbst4jbnnkf7, O_RDWR) failed: No space left on device (28) in Unknown on line 0, referer: http://192.168.1.1/zm/index.php [Sun Dec 05 18:42:10 2010] [error] [client 192.168.1.5] PHP Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php5) in Unknown on line 0, referer: http://192.168.1.1/zm/index.php [Sun Dec 05 18:42:11 2010] [error] [client 192.168.1.5] PHP Warning: session_start(): open(/var/lib/php5/sess_0qpsln2ut7otallbst4jbnnkf7, O_RDWR) failed: No space left on device (28) in /usr/share/zoneminder/index.php on line 77 [Sun Dec 05 18:42:11 2010] [error] [client 192.168.1.5] PHP Warning: Unknown: open(/var/lib/php5/sess_0qpsln2ut7otallbst4jbnnkf7, O_RDWR) failed: No space left on device (28) in Unknown on line 0 [Sun Dec 05 18:42:11 2010] [error] [client 192.168.1.5] PHP Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php5) in Unknown on line 0 [Sun Dec 05 18:42:33 2010] [error] [client 95.52.210.96] Invalid URI in request u\xc8g\x1a?;\xb8\x1e\xd6\xe1\xe5\xd4)\x17Z{\x11\xd8)D \xe6R\xe8\xbf\x1b\xaci\xd4H\x8b\x91\x19-\xec\xecD\xd2_\xda\xbc\xe4O\x907\x8d\xd2S
And, just to test:Code: Select all
:/var/lib$ ls -l drwx-wx-wt 2 root root 4096 2010-12-05 17:09 php5
Now, trying to Login again.. And IT WORKED!!! AgainCode: Select all
:/var/lib$ sudo chmod 777 php5 :/var/lib$ ls -l drwxrwxrwx 2 root root 4096 2010-12-05 17:09 php5
dima_the_chief
