marco@ubuntu:~/ZoneMinder-1.22.1$ make install
Making install in src
make[1]: Entering directory `/home/marco/ZoneMinder-1.22.1/src'
g++ -g -O2 -L/usr/lib -L/usr/lib/mysql -o zmc zmc.o zm.o zm_db.o zm_config.o zm_coord.o zm_box.o zm_poly.o zm_image.o zm_event.o zm_zone.o zm_camera.o zm_loc al_camera.o zm_remote_camera.o zm_file_camera.o zm_monitor.o zm_user.o zm_mpeg.o zm_jpeg.o zm_regexp.o zm_signal.o zm_buffer.o zm_debug.o -lavformat -lavcodec -l avutil -lcrypto -lmysqlclient -ldl -lz -ljpeg
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_read_header':
: undefined reference to `dc1394_create_handle'
: undefined reference to `dc1394_get_camera_nodes'
: undefined reference to `dc1394_dma_setup_capture'
: undefined reference to `dc1394_destroy_handle'
: undefined reference to `dc1394_start_iso_transmission'
: undefined reference to `dc1394_dma_unlisten'
: undefined reference to `dc1394_dma_release_camera'
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_read_packet':
: undefined reference to `dc1394_dma_done_with_buffer'
: undefined reference to `dc1394_dma_single_capture'
/usr/lib/libavformat.a(dc1394.o): In function `dc1394_close':
: undefined reference to `dc1394_stop_iso_transmission'
/usr/lib/libavformat.a(ogg.o): In function `ogg_write_header':
: undefined reference to `ogg_stream_init'
: undefined reference to `ogg_stream_packetin'
/usr/lib/libavformat.a(ogg.o): In function `ogg_write_packet':
: undefined reference to `ogg_stream_pageout'
: undefined reference to `ogg_stream_flush'
/usr/lib/libavformat.a(ogg.o): In function `ogg_write_trailer':
: undefined reference to `ogg_stream_clear'
/usr/lib/libavcodec.a(dtsdec.o): In function `dts_decode_init':
: undefined reference to `dts_init'
/usr/lib/libavcodec.a(dtsdec.o): In function `dts_decode_frame':
: undefined reference to `dts_frame'
: undefined reference to `dts_blocks_num'
: undefined reference to `dts_block'
: undefined reference to `dts_samples'
: undefined reference to `dts_syncinfo'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_init':
: undefined reference to `vorbis_info_init'
: undefined reference to `vorbis_encode_init_vbr'
: undefined reference to `vorbis_analysis_init'
: undefined reference to `vorbis_block_init'
: undefined reference to `vorbis_comment_init'
: undefined reference to `vorbis_comment_add_tag'
: undefined reference to `vorbis_analysis_headerout'
: undefined reference to `vorbis_comment_clear'
: undefined reference to `vorbis_encode_init'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_frame':
: undefined reference to `vorbis_analysis_buffer'
: undefined reference to `vorbis_analysis_wrote'
: undefined reference to `vorbis_analysis_blockout'
: undefined reference to `vorbis_analysis'
: undefined reference to `vorbis_bitrate_addblock'
: undefined reference to `vorbis_bitrate_flushpacket'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_close':
: undefined reference to `vorbis_block_clear'
: undefined reference to `vorbis_dsp_clear'
: undefined reference to `vorbis_info_clear'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_init':
: undefined reference to `vorbis_synthesis_headerin'
: undefined reference to `vorbis_synthesis_init'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_frame':
: undefined reference to `vorbis_synthesis'
: undefined reference to `vorbis_synthesis_pcmout'
: undefined reference to `vorbis_synthesis_read'
: undefined reference to `vorbis_synthesis_blockin'
/usr/lib/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_close':
/usr/lib/libavcodec.a(oggtheora.o): In function `Theora_decode_frame':
: undefined reference to `theora_decode_packetin'
: undefined reference to `theora_decode_YUVout'
/usr/lib/libavcodec.a(oggtheora.o): In function `Theora_decode_end':
: undefined reference to `theora_info_clear'
: undefined reference to `theora_comment_clear'
/usr/lib/libavcodec.a(oggtheora.o): In function `Theora_decode_init':
: undefined reference to `theora_info_init'
: undefined reference to `theora_decode_header'
: undefined reference to `theora_decode_init'
/usr/lib/libavcodec.a(libgsm.o): In function `libgsm_init':
: undefined reference to `gsm_create'
/usr/lib/libavcodec.a(libgsm.o): In function `libgsm_close':
: undefined reference to `gsm_destroy'
/usr/lib/libavcodec.a(libgsm.o): In function `libgsm_encode_frame':
: undefined reference to `gsm_encode'
/usr/lib/libavcodec.a(libgsm.o): In function `libgsm_decode_frame':
: undefined reference to `gsm_decode'
collect2: ld returned 1 exit status
make[1]: *** [zmc] Error 1
make[1]: Leaving directory `/home/marco/ZoneMinder-1.22.1/src'
make: *** [install-recursive] Error 1
this is my error. I think that the error depend of ffmpeg. How can i install zm without ffmpeg on Ubuntu 5.10?
Install ZM on Ubuntu
- zoneminder
- Site Admin
- Contact:
ZM 1.22.1 and Ubuntu 5.10
As far as I can tell, this is a problem with recent ffmpeg binaries & source, and I'm not so sure omitting ffmpeg is really an option with Zoneminder. (disclaimer -- this is the first time I tried building ZM from scratch, and by no means do I actually consider myself knowledge in linux).
I was able to complete "make install" by downloading the most recent ffmpeg source from cvs and hand-editing files in libavcodec and libavformat to remove references to the offending codecs (oggvorbis, theora, libgsm, dc1394). I couldn't seem to get the ffmpeg configure script to disable the codecs (e.g.: "--disable-encoder=OGGVORBIS"), and even if I edited the config.mak file to remove references to those codecs, it didn't seem to make a difference when I ran make.
I could be entirely wrong about the configure options, but by this time my system was quite dirty, so YMMV.
...This was entirely an academic pursuit on a virtual system, but it was good practice for when I actually try this on Ubuntu 6.06 on my current ZM machine (currently running the LiveCD)...
Just FYI here was the build system:
Asus A7V8X-MX SE
AMD Athlon XP 2400+
Maxtor Maxline 300GB HDD
VMWare Workstation 5.0
Host OS: Windows XP
Guest OS: Ubuntu 5.10 full install, 10GB HDD, 512MB RAM, Bridged Network
I learned quite a bit through this exercise, and I would've loved to see if I could actually run ZM through the VM, but I don't have any more time nor capture cards...
- a zmuser -
Asus A7V8X-MX SE
AMD Athlon XP 2400+
Host OS: Windows XP
- a zmuser -
