Noob Questions about setting up a Kodicom 4400R
I'm new to Linux, but not PC's.
I've built a ZM box from the ISO cd, and have installed a Kodicom 4400R card. This is deteded by the OS and by ZM
On the GUI desktop I have four icons labelled TVTime BT878 Video (*** Unknown Gender.
Within ZM I've added the four video devices - but I cant see any images on any of the 4 ports. In ZM if I select montage then I get two black screens and two blue screens - as I only have two cameras connected this looks like something has been detected - but is not configured correctly.
Where do I start the troubleshooting?
which iso you using and if you search for 4400r you will find an excellent post by conner that details the whole process of the kodicom!
James Wilson
you need kernel 2.6.12 minimum
Id either use Ross's new install cd or Coreys ctu zm linux.
I havnt used the new mandriva cd but coreys is based on 2.6.12
James Wilson
I've found this info for Zmdv_2006 Mandriva ZoneMinder installer CD - is this what I need?
http://www.zoneminder.com/forums/viewto ... f5fedee00c
I'm downloading the Bit Torrent now.
Does this mean I need to completely reinstall?
You will find links for most everything in the downloads section or in the LiveCD topic Ross posts what you need as annoucments.
You don't mention which iso you have loaded. There are several. All the ones put out by Ross are Mandrake/Mandriva based. The one I have out is based on FC3.
There will be a FC5 Based distro as well fairly soon.
Cheers,
Corey
Cheers,
Corey
OK I've downloaded the ZoneMinder FC3 Distro v1.21.3 BT CD and rebuilt the box on FC3
The kernel is now verion 2.6.12-1
I've run the command MODPROBE bttv gbuffers=16 card=133,132,133,133 and added the monitors back into ZM
However I'm almost back to where i started as I now have a montage of four black monitors.
I'm not convinced that I have a new enough Kernel as this link
http://linuxtv.org/v4lwiki/index.php/Kodicom_4400R
suggests that I need 2.6.12-6 and 2.6.13 is the baseline.
Am I still missing something? I know my 4400R card works as I've tested it in the same PC with a Windows XP HDD.
Any help would be much apprecited.
thanks
thanks
your right about the kernel. Im sorry i thought that ctu krernel was new enough, but it would appear not. Im not sure if you can update the kernel as i havnt tried.
James Wilson
yes i have got 4400r's working but with a 2.6.13 kernel
James Wilson
- zoneminder
- Site Admin
- Contact:
Done
James Wilson
