stop button/function doesn't work?
hexa
Post by hexa »
i'm using v1.22.0 with cambozolla java applet to watch recorded video.
Everything else on the system seems to work fine except stop button on this page: (i included picture of it to avoid confusion)
I tryed using it(pressing stop button) with Safari, Camimo and Internet explorer on native windows instalation with no luck.
Does any1 have any ideas what to try or how to locate the cause of this problem?
zoneminder
Site Admin
Post by zoneminder »
I am looking into this now. I may have forgotton myself what that button does. It doesn't stop the current event from being replayed (as it's a one way stream) but prevents the next event in the sequence from being loaded after this event has finished. So it just interrupts a 'play all' sequence. I still need to check if it's doing it right though. It's not a heavily used feature.
Phil
hexa
Post by hexa »
Aha, now I understand. It's not supposed to stop right away.
So now i can say stop button works as intended, but after the end of the currently displayed event stop button still remains and i still can't find Play All button.
There exists Replay button (all the time) in the upper left corner if i press it (after stop has stopped displaying of next video stream), it works as intended? - it replays last watched event and continues to play all other selected events.
But it doesn't work like that if i choose (after stop) different rate speed. I click stop then wait for it to stop, choose another speed rate and then click replay. It just plays last/current event again (with different speed as selected) and stops. It should go forward with next event (at the same rate) but it doesn't, it just stops.
You can probably reproduce this error the same way. Select multiple events, click view and change speed rate. You will notice that only one (current) event will be replayed and will not be followed by display of any other previously selected.
I hope i wrote this clear enough.
zoneminder
Site Admin
I will try and reproduce this error. I'm away for a few days now but will do it when I return.
Phil
hexa
Post by hexa »
Cool.
I'll check back on the progress ;-)
