Changes in source settings make streaming window 4x size
ekiboy69
Post by ekiboy69 »
Just bumped into a new problem with 2 boxes running 1.22.1 on Mandrake 10.1/10.2.
If you adjust the source-settings, for example change fps settings, the "live view" opened by clicking the monitor name in the console view shows the picture in 4x size. Quite uncomfortable ;-)
I thought I messed up with the first box but I was able to replicate the problem with another box up and running.
ekiboy69
Possible explanation
Post by ekiboy69 »
Until this is solved I think this might be a permissions problem:
http://www.zoneminder.com/forums/viewtopic.php?t=6304
ekiboy69
I don't think it is a permissions thing
Post by ekiboy69 »
For some reason this thing is on 2 different boxes. I wonder what could cause it?
ekiboy69
The default setting for viewing size has changed to 4x
Post by ekiboy69 »
I noticed that in all windows that show streaming content the size is 4x.
I'm using RPMs built for mandrake and running 1.22.2 at the moment.
Am I really the only one having this problem?
jameswilson
Post by jameswilson »
I have had this but i dont mes with the source much so after i fix it i dont get it again, so i havnt spent any time looking into it sorry
James Wilson
rdmelin
Post by rdmelin »
In the source settings there is a misc tab. There you can select Default scale. Check what you have this set to.
jameswilson
oh i thought it kept reverting to 4x every time you cahnged the source. Oh well i should ask these things i suppose! lol
James Wilson
ekiboy69
Ross found out the right answer
Post by ekiboy69 »
rdmelin wrote:In the source settings there is a misc tab. There you can select Default scale. Check what you have this set to.
This was set to 4x. It is of course possible that I have messed up this on both of the 2 boxes I had this problem with. Anoher possible expalation is that there's something with the rpm update method that caused this.
Well, in any case you guys helped me out again.
Thank you!
