where is ZM on the new Mandriva 2006 Live CD?
hopefully i not being as stupid as i sound to myself, but:
i have downloaded the latest liveCD, burnt the iso, run the CD, and booted into the OS.
but i cannot find out how to start ZM!
i have checked the system icons in the bottom right.
i have checked the quick-linked apps in the bottom left.
i have trawled through the program menu and found no sign of ZM
there are no launcher icons on the desktop.
the initial documentation makes no mention of how to start ZM, it merely talks about default network settings.
i can find nothing of aid on the ZM website, or in the wiki.
the hardware involved is:
Sempron64 @ 1.6GHz
512MB DDR400
Via K8M800 motherboard with onboard Unichrome Pro Graphics
80GB HD
Logitech USB webcam
am i being stupid?
many thanks for any help
R3MF
Sempron64 @ 1.6GHz
512MB DDR400
80GB HD
Logitech USB webcam
am i being stupid?
R3MF
have you downloaded the 1.22.2 live cd or the other one,
If its the live cd and the iso was called it then open a web browser and goto url
http://localhost/zm/
and all should appear.
To check goto a command propt and type
service zm restart and post your results, that will show if zm is running ok
James Wilson
localhost worked fine cheers.
didn't realise it was a web administered application from start to finish.
however, the default "monitor 1" is not seeing my Logitech USB camera, and i cannot find an option in the settings to point "monitor 1" to said camera..............
according to the manual, everything is setup correctly, tho i can find nothing to corralate to the reference to monitor status being "green" in ZM itself. all writing for monitor 1 is blue atm.
the monitor viewing tab itself appears to be ok, but no image is displayed, (just the broken image symbol in the top-right) even tho the camera is attempting to update.
cheers
cheers
id check zm is there before sorting your sources but if its not shpowing in zaw you will struggle to get it running in zm
James Wilson
i did the check and ZM stopped and then started ok.
still no image in the monitor window, just the broken image icon.
i think the camera is supported, tho i cannot now find the list on the website.
but ZM does appear to be running, its just not picking up the camera. maybe it is a USB issue as i know the camera functions under windows...........
many thanks
many thanks
It depends on how new the camera is. From http://qce-ga.sourceforge.net/the camera is a QuickCam Express
The qc-usb, quickcam, and spca5xx drivers are all included on the CD. So the camera will probably work with one of them if the correct one gets loaded.Supported Cameras
The qc-usb driver is known to work with the following webcams:
* Dexxa Webcam
* Labtec Webcam (old model)
* LegoCam
* Logitech QuickCam Express (old model)
* Logitech QuickCam Notebook (some models)
* Logitech QuickCam Web
Unsupported Cameras
Certain new Logitech QuickCam Express and Labtec cameras are reported not to work. These cameras have product IDs of 0x920 and 0x921. For these cameras, you might be able to use the SPCA5xx driver, which incorporates and, evidently, obsoletes this experimental driver.
Take a look at the out put from the commands "dmesg" and "lsmod" and perhaps post them here.
Also helpful would be error messages in /var/log/syslog and /var/log/zm/*
dmesg:
3rdparty/usb-spca50x/drivers/usb/spca561.h: [spca561_init:497] Find spca561 USB
Product ID 928
Product ID 928
irq 10: nobody cared (try booting with the "irqpoll" option)
[<c0142ee4>] __report_bad_irq+0x24/0x90
[<c0142fe6>] note_interrupt+0x96/0x260
[<c0142853>] handle_IRQ_event+0x33/0x70
[<c0142976>] __do_IRQ+0xe6/0xf0
[<c0105439>] do_IRQ+0x19/0x30
[<c0103882>] common_interrupt+0x1a/0x20
handlers:
[<f8e4e180>] (usb_hcd_irq+0x0/0x60 [usbcore])
[<f8f120a0>] (rhine_interrupt+0x0/0xc10 [via_rhine])
[<f8c55480>] (via_driver_irq_handler+0x0/0x1d0 [via])
Disabling IRQ #10
Product ID 928
bootsplash 3.1.6-2004/03/31: looking for picture...<6>...found (800x600, 9805 by
tes, v3).
bootsplash: status on console 0 changed to on
tes, v3).
bootsplash: status on console 1 changed to on
tes, v3).
bootsplash: status on console 2 changed to on
tes, v3).
bootsplash: status on console 3 changed to on
tes, v3).
bootsplash: status on console 4 changed to on
tes, v3).
bootsplash: status on console 5 changed to on
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
Product ID 928
usb 2-2: USB disconnect, address 3
3rdparty/usb-spca50x/drivers/usb/spcausb.h: reg write: error -19
3rdparty/usb-spca50x/drivers/usb/spca5xx.c: Set packet size: set interface error
3rdparty/usb-spca50x/drivers/usb/spca5xx.c: init isoc: usb_submit_urb(0) ret -19
3rdparty/usb-spca50x/drivers/usb/spca5xx.c: [spca5xx_open:2437] DEALLOC error o n init_Isoc
lsmod:
Module Size Used by
via 46528 1
drm 70772 2 via
snd_seq_dummy 3556 0
snd_seq_oss 32836 0
snd_seq_midi_event 7200 1 snd_seq_oss
snd_seq 52716 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi_event
snd_pcm_oss 51008 0
snd_mixer_oss 18016 1 snd_pcm_oss
snd_via82xx 27992 0
gameport 15176 1 snd_via82xx
snd_ac97_codec 91968 1 snd_via82xx
snd_ac97_bus 2144 1 snd_ac97_codec
snd_pcm 86500 3 snd_pcm_oss,snd_via82xx,snd_ac97_codec
snd_timer 23844 2 snd_seq,snd_pcm
snd_page_alloc 10504 2 snd_via82xx,snd_pcm
snd_mpu401_uart 7648 1 snd_via82xx
snd_rawmidi 25280 1 snd_mpu401_uart
snd_seq_device 8780 4 snd_seq_dummy,snd_seq_oss,snd_seq,snd_rawmidi
snd 53152 11 snd_seq_oss,snd_seq,snd_pcm_oss,snd_mixer_oss,snd_via82xx,snd_ac97_codec,snd_pcm,snd_timer,snd_mpu401_uart,snd_rawmidi,snd_seq_device
soundcore 9600 1 snd
parport_pc 27468 1
lp 12512 0
parport 36520 2 parport_pc,lp
af_packet 22280 2
amd64_agp 12292 1
sis_agp 8548 0
agpgart 31912 3 drm,amd64_agp,sis_agp
bt878 11084 0
bttv 173020 1 bt878
video_buf 22180 1 bttv
compat_ioctl32 1216 1 bttv
i2c_algo_bit 9032 1 bttv
v4l2_common 7712 1 bttv
btcx_risc 5000 1 bttv
ir_common 9572 1 bttv
tveeprom 14608 1 bttv
i2c_core 21536 3 bttv,i2c_algo_bit,tveeprom
spca5xx 672152 0
videodev 9408 2 bttv,spca5xx
floppy 64080 0
usbhid 49152 0
via_rhine 24420 0
8139too 27200 0
mii 5728 2 via_rhine,8139too
unionfs 302472 1
squashfs 44784 1
3w_xxxx 27200 0
mptscsih 36656 0
sx8 18508 0
tmscsim 22624 0
sata_vsc 8388 0
sata_via 8420 0
sata_uli 7204 0
sata_sx4 13988 0
sata_svw 7812 0
sata_sis 7940 0
sata_sil 9992 0
sata_qstor 9604 0
sata_promise 11716 0
sata_nv 9508 0
dmx3191d 12704 0
BusLogic 72164 0
aic7xxx 172368 0
ahci 13572 0
usb_storage 79200 0
ehci_hcd 30408 0
ohci_hcd 20868 0
uhci_hcd 32208 0
usbcore 128832 7 spca5xx,usbhid,usb_storage,ehci_hcd,ohci_hcd,uhci_hcd
mptbase 50020 1 mptscsih
scsi_transport_spi 23392 2 dmx3191d,aic7xxx
sd_mod 18368 0
sg 35704 0
ata_piix 10596 0
libata 61584 12 sata_vsc,sata_via,sata_uli,sata_sx4,sata_svw,sata_sis,sata_sil,sata_qstor,sata_promise,sata_nv,ahci,ata_piix
sr_mod 17604 0
scsi_mod 135020 15 3w_xxxx,mptscsih,tmscsim,sata_sx4,sata_promise,dmx3191d,BusLogic,aic7xxx,ahci,usb_storage,scsi_transport_spi,sd_mod,sg,libata,sr_mod
loop 16104 2
ide_cd 40512 1
cdrom 37424 2 sr_mod,ide_cd
isofs 35904 1
nls_utf8 1984 0
ntfs 107572 0
vfat 13120 0
msdos 10048 0
fat 53116 2 vfat,msdos
reiserfs 265524 0
ext3 134536 0
jbd 56628 1 ext3
nls_cp437 5664 0
nls_iso8859_2 4608 0
nls_iso8859_1 4032 1
[guest guest]$
id log in as root then as the auto login is only guest, and very limited, i think you can su so that konqurer works but i dont know how. It looks like its the usb, id try and get it working in xaw first as at least you can see instant success, then try to ge it going in zm
James Wilson
The easy way to view log files is to use the "tail" command. If you rum this in a konsole window you can view the last "n" lines of a file. Run as root or use sudo for files where you need permissions.
Example:
"sudo tail -n 20 /var/log/zm/zmpkg.log"
Use "tail -f" to keep the view open and watch messages as they are written to the log.
A shortcut is configured for guest to alias "sudo tail -f /var/log/syslog" to just "sys". Try it, you'll like it
Just for fun try (as root) "modprobe -r spca5xx && modprobe quickcam" and check dmesg again. Then "modprobe -r quickcam && modprobe qc-usb" and dmesg again. Perhaps one of these drivers will work.
Example:
