Zoneminder alarm max fps and alarm state
jameswilson
Post by jameswilson »
ok leave that for a bit and see what your recprded events look like, its possible that the machine is overloaded, What cameras/card you using, I also think that 10 cams are too much for a 1.1 Ghz machine. I have a duron 750 at home that I use that manages 2 with mocord but any more is a push for it i would say 4 max regardless of ram count, but lets see
James Wilson
Dr_AxiA
Post by Dr_AxiA »
now load average is 1.54 ca. ... also i have the idea that 10 cameras is more for 1.1GHz cpu....now i think upgrade this at 1.8 GHz...but i had 10 cameras that captured at 1.00 Fps...is more for this CPU??
i have 6 digital http cameras and 4 analogic cameras connect to an AXIS 2400 Video Server...and for card you think the video-card?? is integrate with mainboard...is an Intel video card....
jameswilson
with only 1 cam enabled is it working as expected?
I think that 1.1 Gig i s possibly ok for 10 cams at 1 fps, what resolution are you capturing at?
James Wilson
Dr_AxiA
Post by Dr_AxiA »
resolution 352x288 for axis, other resolution is 320x224
jameswilson
has it been ok on only 1 cam?
James Wilson
Dr_AxiA
Post by Dr_AxiA »
it seems ok...but now i try to connect via ftp....for look if it's a best method for this configuration....perhaps is strange...with set Max Fps parameter zma enter in state alarm e zmc exit abnormally...it seems that ZoneMinder hasn't capacity of capture frame at Max Fps setting...and when zmc capture frame at more disequal framerate, zma enter in alarm state...
jameswilson
sorry i dont understand the ftp comment?
James Wilson
Dr_AxiA
Post by Dr_AxiA »
now i try to connect to camera via ftp and not via http...
jameswilson
i have never tried over ftp, i didnt even know you could! But i would have thought that http would be better
James Wilson
Dr_AxiA
Post by Dr_AxiA »
hmmm...what you say maybe is true, but i must try.... :wink: ...but it's more difficult... :P
Dr_AxiA
Post by Dr_AxiA »
could be the channel DMA speed??or type of partition which i use??now for archive image and convert to mpeg i use an ext3 partition...must i use a XFS partition???
jameswilson
now im really lost!
Do you still have a problem?
If so what is it, i understood that it was fine when running with 1 cam?
James Wilson
Dr_AxiA
Post by Dr_AxiA »
I explain you...:
1)with 1 camera load average is ok but alarm state persist...
2)i try now with 4 axis in quad mode in 1 source (704x576) and 2 web cam in other 2 source (640x448 for everyone) on 1.8GHz via http-->load average here seems ok
3)i try with 4 web cam in other 1.1 GHz cpu and try via ftp
...but state alarm is on..... :evil:
jameswilson
i have had this with alarm on and i think if you set the zone really slow (unsensitive) turn to mocord wait 10 mins then back to record that should get it. I think it happens when changing to record from mocord/modect when in alarm
James Wilson
Dr_AxiA
Post by Dr_AxiA »
but i set MOCORD/MODECT mode never....i set only RECORD mode and I eliminate the Zones... :roll:
