hi,
I have 6 cams of various flavors connected.
2 COAX
4 IP GS1000's
The first 2 cams (the COAX types) populate immediately when I open MONTAGE. HOWEVER, the other images take several minutes...BUT if I click on an indiviual cam, that action somehow forces to other MONTAGE images to populate immediately.
This IS REPRODUCEABLE!!!
any ideas?
thanks
-frank
MONTAGE population time
I assume this is ie on the client, if you try firedox it will be much quicker
James Wilson
Have you changed you max connections setting yet?
Follow this thead:
http://www.zoneminder.com/forums/viewtopic.php?t=4484
Regards,
Corey
Follow this thead:
Regards,
Corey
- zoneminder
- Site Admin
- Contact:
Not as far as I know (I would think it would be a security risk anyway) but there is some discussion of the FF preferences files etc here which may be useful.
Phil
