Zoneminder alarm max fps and alarm state
ok, is this machine available on line? can i log into it
James Wilson
now i try with 1.22.0 version and state Record is ok....state alarm isn't reach and events is ok....
but my question is: why with version 1.22.1 & 1.22.2 with cameras setting at equal resolution/framerate state alarm is generated and events aren't save at section lenght which I set for every camera???
Is there a special setting or variable which i must set it???
thanks....
thanks....
not that i know of, have you got all 10 cameras working now on 1.22.0 ( i must admit to having less issues with 1.22.2 than 1.22.0)
James Wilson
no...now i have the ultimate configuration that i say you yesterday:
1)on 1.8 GHz cpu 1 source in quad mode for AXIS Video Server (704x576) and other 2 source set on 2 web cameras set to 640x448 resolution....always 1 Fps-->events ok, no state alarm and not abnormally exit on zmc
2)on 1.1 GHz cpu 4 source on 4 web cameras set to 320x224 resolution at 1 Fps-->events ok, no state alarm and not abnormally exit on zmc
and in ZM 1.22.0 ther're ok....yesterday equal configuration in ZM 1.22.1 & 1.22.2 version cause permanent state alarm and zmc exit abnormally...and events were irregular...
i will set my 1.22.2. to record mode and see what happens
James Wilson
I changed mine from mocord to record no problems, then i changed from mocord to record while zone in alarm, and it stayed in alarm. I suppose this is because there is nothing to turn it off
James Wilson
