hai,
can I record in zoneminder 1 camera for 1day stop after the first day
and the 2nd one for two or three days an stop after the second day
if or if not please help me how can I do it
zoneminder recording
If you explain further im sure we can help but i dont understand the question. But yes you can using runs states and cron
James Wilson
if you mean you only want to keep footage from cam1 for 2 days and cam 3 for 3 days you will need to setup custom filters to delete the footage when the footage is n days old. If you mean you only want to record for 2 days then you will need to use cron to change a run state after 2 days to a new run state etc.
James Wilson
