I used a headless test system to evaluate zoneminder, and after I got it working I was happy. I replaced a geoview system with zoneminder, also a headless server and again it worked. I was able to view live feeds and montages.
I replaced two more geovieew systems and these are not headless systems, and I discovered that I cannot view the live streams on the local machine (direct, cycle, montage), but remote viewing is just fine. While the live streams don't show on the local desktop, viewing past events work fine.
Is this a normal occurance or do I have something funky with my systems?
ubuntu 6.06 2.6-15
1G memory
2Ghz celeron
kernel.shmmax = 84217728
firefox 1.5
confirm local viewing is doesn't work?
favorite with the infomation you have given (could do with a bit more info!)
Is that you are using konqerer or other non firefox browser, check you can view stills from the system
James Wilson
to answer your question, yes, I view all the time on my server.
I do it primarily when I am setting up new cameras.
When I am away from the server I a keep Firefox off and the main console logged out to reduce overhead.
________
half-baked
________
half-baked
You should be ok using ff for shorft peroids. The problem comes when you leave it running for days on end
James Wilson
