broken images in view with auth on, ok with auth off
bainssu
Post by bainssu »
I'm using zm 1.22.2,
with the authentication turned off the view is fine and the images come through clean. With the authentication turned on he images in montage view are broken.
has anyone else experienced this..?
regards
Surj
zoneminder
Site Admin
Post by zoneminder »
Can you post the url that the images are being streamed from in both cases? You will have to view the source of the pages and search for zms.
Phil
bainssu
Post by bainssu »
here is the url for a 'regular' view with the auth turned off (works )
http://surj.ath.cx/cgi-bin/nph-zms?mode ... 1152279935
and now with it switched on (don't work)
http://surj.ath.cx/cgi-bin/nph-zms?mode ... 1152279750
jameswilson
Post by jameswilson »
just a thought you are on 1.22.2? as one of the previous versions had some issue with plain auth, you caould also try using plain ath instead of hashed and ee if that makes any difference. Also logs from zms would be nice
James Wilson
bainssu
Post by bainssu »
I'm on 1.22.2, I've just tried with plain auth which still returns a broken image.
here a snippet of some of the logs
/zmdc.log
Corrupt JPEG data: 12 extraneous bytes before marker 0xd9
Corrupt JPEG data: 6 extraneous bytes before marker 0xd9
Corrupt JPEG data: 8 extraneous bytes before marker 0xd9
Corrupt JPEG data: 9 extraneous bytes before marker 0xd9
Corrupt JPEG data: 13 extraneous bytes before marker 0xd9
/tmp/zmwatch.log
07/07/06 11:08:07.786786 zmwatch[9949].INF [Watchdog starting]
07/07/06 11:08:07.787260 zmwatch[9949].INF [Watchdog pausing for 30 seconds]
07/07/06 14:43:56.333546 zmwatch[18033].INF [Watchdog starting]
07/07/06 14:43:56.334023 zmwatch[18033].INF [Watchdog pausing for 30 seconds]
07/07/06 14:49:08.279459 zmwatch[18520].INF [Watchdog starting]
07/07/06 14:49:08.279933 zmwatch[18520].INF [Watchdog pausing for 30 seconds]
07/07/06 15:22:04.650691 zmwatch[18977].INF [Watchdog starting]
07/07/06 15:22:04.651169 zmwatch[18977].INF [Watchdog pausing for 30 seconds]
07/07/06 15:23:11.129821 zmwatch[19159].INF [Watchdog starting]
07/07/06 15:23:11.130301 zmwatch[19159].INF [Watchdog pausing for 30 seconds]
/tmp/zmaudit.log
07/07/06 15:23:10.821275 zmaudit[19154].DBG [Found database monitor '3']
07/07/06 15:23:10.824391 zmaudit[19154].DBG [Got 121 events]
07/07/06 15:23:10.824672 zmaudit[19154].DBG [Found filesystem monitor '1']
07/07/06 15:23:10.825746 zmaudit[19154].DBG [Got 172 events]
07/07/06 15:23:10.825841 zmaudit[19154].DBG [Found filesystem monitor '2']
07/07/06 15:23:10.827365 zmaudit[19154].DBG [Got 270 events]
07/07/06 15:23:10.827490 zmaudit[19154].DBG [Found filesystem monitor '3']
07/07/06 15:23:10.828211 zmaudit[19154].DBG [Got 121 events]
/tmp/zmaudit.log
07/07/06 14:49:07.605655 zmfilter[18510].INF [Scanning for events]
07/07/06 15:22:03.925439 zmfilter[18967].INF [Scanning for events]
07/07/06 15:23:10.516030 zmfilter[19149].INF [Scanning for events]
/tmp/zmpkg.log
07/07/06 14:43:38.660351 zmpkg[17937].INF [Command: restart]
07/07/06 14:48:50.620927 zmpkg[18397].INF [Command: restart]
07/07/06 15:21:46.815675 zmpkg[18881].INF [Command: restart]
07/07/06 15:22:53.594435 zmpkg[19063].INF [Command: restart]
cordel
Post by cordel »
Have you restarted ZM after changing auth states so that the setting are properly passed to all the processes?
Regards,
Corey
