Mobo Beep on error
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
jameswilson
Mobo Beep on error
Post by jameswilson »
If an error occurs (obviously not a fatal one) where zm cannot do what it thinks it can ie record etc video loss etc, can the mobo beeper like er beep. Ideally this would be an enable/disable option. and there could be 2 grades of fault, intermittent and a more serious continous. I ask for this as i had a system that got corrupted and it was streaming great but wouldnt playback as even though image were being written the db couldnt tie them up as it had a problem. Plus the mocord indicators were orange but they didnt tell me till something happened. A beep would have driven them mad and i would have been told about that (purely just to shut it up!!)
James Wilson
zoneminder
Site Admin
Post by zoneminder »
If anyone knows how to trigger a beep then it would be relatively easy to add as a trigger.
Phil
jameswilson
http://www.carcosa.net/jason/software/beep/
Is all the info i can find that i understand
I have found various refences to printf("\a") and /7
I also found this
http://freshmeat.net/projects/beep/
let me know if any of these are any good so i can start looking again if need be.
I suppose if its made to bee p on error it can also beep on motion detection, camera disconnect etc etc?
http://www.developer.com/open/article.php/631191
Above is something in C in case you want to integrate it instead of another dep?
Regards
James
James Wilson
zoneminder
Site Admin
The freshmeat project looks the right sort of thing. I use SmoothWall and that does a triple ascending beep when ready which is cool, so it would probably be more useful to have a small number of differnet patterns and tones.
Phil
jameswilson
I agree. It would be nice if we could turn on varios 'feedback' noises too. The obvious ones are
General Fault
Camera Fault
Motion alarm/alert
Zm start
zm stop
zm change run state
anyone else care to add
James Wilson
jameswilson
Hi Phil, sorry to bump this up, but i had a hd issue today and we didnt know, until we needed to playback! Also a Status page like the alarm one would be good with a basic healthcheck. I could then hook this into zm4ms and errors could be reported to end users. I could also write a monitoring app that would check all server are ok etc from the same page
James Wilson
zoneminder
Site Admin
Are you still talking about the beeps? Or just a general system health page?
If there a simple way to monitor disk health, maybe there is a /proc file that includes disk errors? If so then it should be fairly simple to poll it. However it may be that plugging that kind of thing into Nagios would give more functionality.
Phil
jameswilson
Im thinking both sorry!
Im not so much thinking of disk health etc only zm health. Whats wrong would take investigation or nagios plugins etc
Ideally from mine only point of view as i use mocord or record only
If for any reason its not recording id like it to be made public! I would also like a health page which would show
disk usage
oldest recording
currunt global fps
running/stopped etc
all enabled cams ok
and a table of how the current monitors are set, ie non, monitor, modect etc
Then once this is in place i suppose we could turn beeps on for them too. From my point of view beeps would be more use that sound card outlets as i tend to disable to audio and never fit speakers. I think fancy noises should be part of the client we/I eventually get round to writing
Thanks Phil
James Wilson
