can't delete more than 185 events
I have a strange problem with deteting events. It started with a new install of 1.22.0 and I just upgraded to 1.22.2 and it still happens. No matter how many events I select, only 185 get deleted and I can't figure out why. This is a gentoo AMD64 system using the ebuilds to install. Has anyone had this problem and fixed it?
- zoneminder
- Site Admin
- Contact:
This form uses 'get' rather than 'post' as it can get refreshed automatically and you get browser messages if you refresh a 'post'ed form. Thus the event ids are appended to the url and I think most browsers have a limit to the length of this. Assuming it is 1024 or so, then divide this by the lenth of your ids plus '&' to get the limit.
It is probably a bug, I think it should probably just indicate 'all visible' rather than the ids when you check all of them.
Phil
- zoneminder
- Site Admin
- Contact:
