quit alarm status
marcel
quit alarm status
Post by marcel »
I installed Zoneminder on a debian sarge system.
All seems working.
many thanks to all who made the documentation.
I defined a small zone at the edge of my first camera image.
and then i put the monitor in alarm (moving something inside the zone)
the monitor goes in 'alarm state' and Zoneminder begins to save images in event directory.
My question:
How do I quit alarm status? How is it possible to return to normal status x minutes after an event?
I think I don't understand something may be because my bad english..
best regards
marcel
Marcel
jameswilson
Post by jameswilson »
Unless your settings are wrong the monitor should return to normal after the alarm has passed plus post alarm image count. If would think that you have your zone set a bit to sensitive
James Wilson
dyuen
Post by dyuen »
marcel,
Did you set anything on Linked monitors in montor configuration? If so, delete them and try again.
marcel
Post by marcel »
thank you james, dyuen
for your answers!
I deleted what I put into linked monitors,
now it works.
Marcel
