zone minder does not start
rsadanan
Post by rsadanan »
hai all,
i have a problem in filters,
i used the filter purgefull the default in zoneminder by changing 95 to 90
to delete
for the first two days th filter worked and now the disk is full and i
cannot start zone minder,
i deleted nearly 100 events
again it does start
can anybody tell me what is the problem in it
thanks in advance
jameswilson
Post by jameswilson »
navigate to where your images are stored and remove a few event folders
James Wilson
rsadanan
Post by rsadanan »
ok thanks
i will try to do
now i am not in the server where the zm was installed
RedFlyer
Post by RedFlyer »
James,
That's what he have done has he said in his previous post ...
Oliver
________
Strawberry cough
jameswilson
Posted: Mon Jul 24, 2006 11:51 am Post subject: zone minder does not start
hai all,
to delete
Oliver I took this to mean that his filter worked correclty for 2 days now his disk is full, not that he deleted 2 days worth manually and it still wont work?!
What can happen is if you have made more or modified additional filters eg email/ftp etc and there is an error with one of them it will stop ALL filters from running. You will need to check the logs to find out why your filters are stalling but you need zm to be running first. My previous post will not fix the problem but will 'make' some space to enable zm to start and then the filters to run.
James Wilson
