1024x768 Frame Grabbing
pkmminc
Post by pkmminc »
I am currently running 1.22.2. We have a HD15/DVI Frame Grabber installed and would like to capture with ZoneMinder. Frame Grabber is seen via V4L and works with XAWTV. v4lctl -d /dev/video0 list works and shows all the options for image control.
When I run:
There is no Physical BNC interface on the cards so it mybe part of the board just not attached.
attribute  | type   | current | default | comment
norm       | choice | (null)  | (null)  |
input      | choice | Analog  | Analog  | Analog (HD15) Digital (DVI) Composite (BNC)
Htotal     | int    |       0 |     800 | range is 51 => 4096
Hsync      | int    |       0 |      96 | range is 1 => 4096
Hbp        | int    |       0 |      48 | range is 0 => 4096
Hres       | int    |       0 |     640 | range is 50 => 2047
Vtotal     | int    |       0 |     512 | range is 1 => 4096
Vsync      | int    |       0 |       2 | range is 1 => 2048
Vbp        | int    |       0 |      33 | range is 0 => 2048
Vres       | int    |       0 |     480 | range is 50 => 2047
Interlaced | bool   | off     | off     |
Swap Field | bool   | off     | off     |
Swap Lines | bool   | off     | off     |
AD Int.Cal | bool   | off     | off     |
AD Ext.Cal | bool   | off     | off     |
Detect Tim | bool   | off     | off     |
AD Phase C | bool   | off     | off     |
Phase      | int    |       0 |     255 | range is 0 => 511
Scaling    | choice | Disable | Disable | Disabled Max Fill Max Aspect
Horz. Pos  | choice | Centere | Centere | Centered Left Right
Vert. Pos  | choice | Centere | Centere | Centered Top Bottom
Borders    | choice | Black   | Black   | Black White Red Green Blue Cyan Magenta Yellow
Fit Corner | bool   | off     | off     |
  #zmu -q -d /dev/video0
  #error22
When I add the -v switch I get:
  #zmu -q -v -d /dev/video0
  #Error: Failed to get video capablities /dev/video0: Invalid Argument
So do the additional arguments need to be added to just the database or would I also have to modify the source?
