I am dealing with either a flakey camera or wireless AP. I hope to solve that problem soon. In the meantime it appears that when zmc times out on a select it gets restarted:
Jul 31 11:05:59 rascal zmwatch[6606]: INF ['zmc -m 1' started at 06/07/31 11:05:59]
Jul 31 11:06:03 10.0.0.253 Wireless PC connected 00-01-36-09-29-b4^M
Jul 31 11:12:30 rascal zmc_m1[20582]: ERR [Select timed out]
Jul 31 11:12:30 rascal zmdc[6567]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Jul 31 11:12:39 rascal zmwatch[6606]: INF [Restarting capture daemon for web, time since last capture 12 seconds (1154369559-1154369547)]
Jul 31 11:12:40 rascal zmdc[20857]: INF ['zmc -m 1' started at 06/07/31 11:12:40]
But if when it restarts it gets a time out, it does not get restarted:
Jul 31 11:12:40 rascal zmc_m1[20857]: INF [Debug Level = 0, Debug Log = <none>]
Jul 31 11:12:40 rascal zmc_m1[20857]: INF [Starting Capture]
Jul 31 11:15:49 rascal zmc_m1[20857]: ERR [Can't connect to remote camera: Connection timed out]
Jul 31 11:15:49 rascal zmdc[6567]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Jul 31 11:23:50 rascal zmpkg[21321]: INF [Command: restart]
Is there anyway to get zm to retry the startup of zmc? I am using v1.22.1.
Mike
I'm not sure of the exact name but I think you drop the check capture demon time and that will do it for you, its one of the capture demon settings anyway, my memory is awful these days plus with some of the other questions we have had on here latly search is obviously broken!
James Wilson
Ill try that, but I don't think thats the problem.
Now after the thing has been bouncing up and down a lot I am getting:
Jul 31 20:30:09 rascal zmwatch[13610]: INF [Restarting capture daemon for web, shared memory not valid]
Jul 31 20:32:00 rascal zmwatch[13610]: ERR [Can't get shared memory id '7a6d2001', 1: No such file or directory]
Jul 31 20:32:00 rascal zmwatch[13610]: INF [Restarting capture daemon for web, shared memory not valid]
I think I will need to reboot my system.
yeah there not right. But the shared mem not valid usually mernas you are trying to live view from a cam that currently cant get images. If your having wireless issues this would be correct
James Wilson
