Proper disconnect from web page - ttl lsof
amp
Post by amp »
I use a proxy to access a remote camera server behind a firewall
I am streaming live video from the remote server using the following html code on my web page:
http://www.allenintech.com/cgi-bin/zms? ... =10&ttl=30
Of course the streaming stops after 30 seconds (due to ttl=30)
When I access the web page and list open files using,
/usr/sbin/lsof -i tcp:80,
Open connections from the client to the remote server are properly shown. See partial listing of lsof command:
    TCP allenintech.com:http->wme.allenintech.com:59419 (ESTABLISHED)
    TCP allenintech.com:60790->aitsurv.allenintech.com:http (ESTABLISHED)
When te web page is closed, lsof i tcp:80 show the connections closed:
    TCP *:http (LISTEN)
    TCP *:http (LISTEN)
Since I want "continuous streaming", I eliminated the ttl parameter or set it to zero.
I can view the live feed from the remote camera server. lsof -i tcp: 80 shows the connection from the client to the remote server. See partial listing below:
    TCP allenintech.com:http->wme.allenintech.com:59023 (ESTABLISHED)
    TCP allenintech.com:62345->aitsurv.allenintech.com:http (ESTABLISHED)
BUT when the web page is closed, the connection to the remote camera server remains open as shown by the following lsof -i tcp: 80 command:
  • (NOTE: ttl=0 or ttl is eliminated in the parameter list)
As you can guess, after many opening and closing of the web page, particularly when viewing multiple camera these "bogus / phantom " open / ESTABLISHED connection degrade system performance significantly.
Can anyone point me to how to stream the video and have the remote server properly disconnect when the web page is close?
I am running zm 1.21.4
proxy server: RH 9.0, apache 2.0.40
remote server: Fedora 4, apache 2.0.54
Thanks in advance
amp
"Truth is so obscure in these times and falsehood so established that unless you love the truth you will not know it."
Blaise Pascal
