Update RPMs for ZMliveCD/Mandrake/Mandriva installations
Ross's RPM's
Is it me or can anyone get at ross's rpm's.
Do we have any other copies anywhere as i urgently need to do an 1.22.0 upgrade!
Ill put them on my server too when we have them back
cheers
cheers
James Wilson
Re: Ross's RPM's
Hi James,jameswilson wrote:Is it me or can anyone get at ross's rpm's.
cheers
Did you find ross's rpms anywhere else? You are right, both links to the rpms are out. Please let me know if you already got them.
Thanks,
amppjunior
i found an old 1.22.2 10.1 rpm and used that. I can put that on my server later if your stuck, plus i have an upto date mandriva 2006 rpm too
James Wilson
now they wont, but Ross released a mandrake 2006 cd with all dependencies installed by default
James Wilson
I already tried the Mandriva 2006 live CD, but it does not recognize SATA HD. I had to install from Mandriva 2006 3 CDs to recognize my HD. The problem is that I need a kernel version greater than 6.12.12-6 to work with my video card, so I can't use the Mandriva 10.1 live CD as I've already tried it with no success. That is the reason I need Ross's rpm to Mandriva 2006 instalation. Anyway, thank you for your help James and if you still have the files, please let me know.jameswilson wrote:now they wont, but Ross released a mandrake 2006 cd with all dependencies installed by default
Amppjunior
I have found these and put them on my server in the following locations.
2006 rpm
http://www.jpwilson.eu/zm-1.22.2-9_20060mdk.i586.rpm
10.1 (older version of 1.22.2-7)
http://www.jpwilson.eu/zm-1.22.2-7_101mdk.i586.rpm
Ross (and Corey if you see this)
I will setup a Ross and Corey part to my website and will host any files you want me too, just send them me and ill put them on the site
2006 rpm
James Wilson
Should i apply the RPM?
I has downloaded and installed on hard disk "ZMliveCD_1.22.2.1.iso" and has seen that there is "zm-1.22.2-9_20060mdk.i586.rpm".
Should i install or upgrade Zoneminder that is installed in the hard disk from livecd with new RPM?
If so, what is the procedure.
I am new on Zoneminder and for instance has had a problem indicating that a user has left the database open. That could corrupt Mysql and found on the forum a script to fix that. But this post was about an older version of Zoneminder. ¿How do i know if those patch, fixes, etc that i read about in this forum are or not incorporated in the newer version?
Gola10
Gola10
you can follow the instructions already provided for upgrading via rpm. But your dberror is usually caused by a server crash power down etc and is not a bug in 1.21.x
James Wilson
Thanks Ross, Can the 2006 one be used on the 10.1 zm live cd?
Thanks mate
Thanks mate
James Wilson
No. I thought I'd see if anyone requested RPMs for 10.1. I no longer maintain a 10.1 system to test on. The 2006 based CDs allow me to rebuild and test running from the CD.Can the 2006 one be used on the 10.1 zm live cd?
If there is a demand for it I will rebuild 10.1 RPMs but am sort of hoping everyone has moved up to the later versions.
ill rebuild mine at home then
James Wilson
