Call to undefined function mysql_pconnect()
DiegoLima
Post by DiegoLima »
Hello, I managed to compile zoneminder from source and install it on my system, however when I access http://localhost/zm I get this error:
Fatal error: Call to undefined function mysql_pconnect() in /var/www/zm/zm_db.php on line 21
I am using Ubuntu 6.06 (dapper), apache 2, mysql-server 5.0.22 and php5.
acrid
Post by acrid »
did you install the phpX-mysql package?
$> man woman
$> Segmentation fault (core dumped)
chippy99
Post by chippy99 »
I had same problem and it was fixedby removing semi-colon from in front of
extension=mysql.so in php.ini.
On ubuntu php.ini is located in /etc/php5/apache2 directory.
trustf8
Call to undefined function mysql_pconnect()...php on line 21
Post by trustf8 »
Check if you have installed all modules which interact php , apache, mysql
apache*-mod-php*
php*-mysql
