zm_mpeg compile error: 'struct AVCodecContext**"
trelane
Post by trelane »
This issue has previously cropped up here but as the last post in the thread was in april with a complaint of the issue resurfacing I am starting a new thread:
http://www.zoneminder.com/forums/viewto ... deccontext
I am using ZoneMinder-1.22.2, and ffmpeg from SVN (centos 4.3 on a P3) checked out this morning. The compile is dieing as follows:
then mv -f ".deps/zm_user.Tpo" ".deps/zm_user.Po"; else rm -f ".deps/zm_user.Tpo"; exit 1; fi
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -I/usr/include -g -O2 -MT zm_mpeg.o -MD -MP -MF ".deps/zm_mpeg.Tpo" -c -o zm_mpeg.o zm_mpeg.cpp; \
then mv -f ".deps/zm_mpeg.Tpo" ".deps/zm_mpeg.Po"; else rm -f ".deps/zm_mpeg.Tpo"; exit 1; fi
zm_mpeg.cpp: In member function `void VideoStream::SetupCodec(int, int, int, int, int)':
zm_mpeg.cpp:88: error: cannot convert `AVCodecContext**' to `AVCodecContext*' in initialization
zm_mpeg.cpp:109: error: 'struct AVCodecContext' has no member named 'frame_rate'
zm_mpeg.cpp:110: error: 'struct AVCodecContext' has no member named 'frame_rate_base'
zm_mpeg.cpp: In member function `void VideoStream::OpenStream()':
zm_mpeg.cpp:161: error: cannot convert `AVCodecContext**' to `AVCodecContext*' in initialization
zm_mpeg.cpp: In destructor `VideoStream::~VideoStream()':
zm_mpeg.cpp:256: error: cannot convert `AVCodecContext**' to `AVCodecContext*' for argument `1' to `int avcodec_close(AVCodecContext*)'
zm_mpeg.cpp: In member function `double VideoStream::EncodeFrame(uint8_t*, int, bool, unsigned int)':
zm_mpeg.cpp:303: error: cannot convert `AVCodecContext**' to `AVCodecContext*' in initialization
make[2]: *** [zm_mpeg.o] Error 1
make[2]: Leaving directory `/root/ZoneMinder-1.22.2/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/ZoneMinder-1.22.2'
zoneminder
Site Admin
Post by zoneminder »
Have a look and see if the Patch on the Wiki for this works for you.
Phil
rwmarch
Post by rwmarch »
FYI, attempting to build on SUSE10.1, make failed with the following:
zm_mpeg.cpp:88: error: cannot convert ‘AVCodecContext**’ to ‘AVCodecContext*’ in initialization
zm_mpeg.cpp:109: error: ‘struct AVCodecContext’ has no member named ‘frame_rate’
The ffmpeg patch in the wiki has fixed it.
-Robert
ManRoaming
zm_mpeg.h
Post by ManRoaming »
Well here is the garbage that spewed forth AFTER I applied the patch with no reported error. This has turned into a real science project.
zm_mpeg.cpp: In member function ‘void VideoStream::SetupCodec(int, int, int, int, int)’:
zm_mpeg.cpp:110: error: ‘struct AVCodecContext’ has no member named ‘frame_rate_base’
zm_mpeg.cpp: In member function ‘void VideoStream::OpenStream()’:
zm_mpeg.cpp:161: error: cannot convert ‘AVCodecContext**’ to ‘AVCodecContext*’ in initialization
zm_mpeg.cpp: In destructor ‘VideoStream::~VideoStream()’:
zm_mpeg.cpp:256: error: cannot convert ‘AVCodecContext**’ to ‘AVCodecContext*’ for argument ‘1’ to ‘int avcodec_close(AVCodecContext*)’
zm_mpeg.cpp: In member function ‘double VideoStream::EncodeFrame(uint8_t*, int, bool, unsigned int)’:
zm_mpeg.cpp:303: error: cannot convert ‘AVCodecContext**’ to ‘AVCodecContext*’ in initialization
make[2]: Leaving directory `/usr/local/ZoneMinder-1.22.2/src'
make[1]: Leaving directory `/usr/local/ZoneMinder-1.22.2'
make: *** [all] Error 2
DidI apply the patch wrong? WTF?
Anyway, HELP!
essup
Post by essup »
Well, how did you apply the patch then? Are there any error messages?
ManRoaming
Fixed it already, thanks anyway. I am up and runnung now with gray scale pictures. fixing the color is next.
jameswilson
Post by jameswilson »
how did you fix it?
James Wilson
ManRoaming
re patch
Applied the patch, re-configured, re-made, re-installed. It works fine but only grayscale works. Funny the color works when running xawtv. Source goes red on the console and video stops when trying rgb24. Probably some tweak I haven't found yet.
jameswilson
are your running at a res higher than 320x240?
James Wilson
ManRoaming
color
Running 320X240 on all 6 CCD cameras. Same res displays color on all cams when looking through the BTTV card with xawtv. I have 3 BTTV cards in this PC, all clones bought on E-Bay. I'm probably missing a tewak somewhere, and theres planty of them in this package. Took me about a week of playing to get it running as it is. Grayscale pix looks good.
jameswilson
and you have set all the paleets to 24 bit? That is wierd
James Wilson
ManRoaming
fixed
Well I found the trick. I set all sources to RGB24 and restarted ZM. Now I have color on all cam feeds. I'm gonna screw with motion detection, recording, and web access later. Basking in this small victory for now.
