Capture Problem: 1.22.2 vs 1.21.3 with Axis 2100 Cams
Axel
Post by Axel »
Yes, indeed. The cam stucks. This is the first time. Maybe because i use MPEG now? After restart the cam, the problem with zoneminder is the same.
You can access now the 207, use the same link i sent but port 92, please.
jameswilson
Post by jameswilson »
so to clarify how do you get this working again
do you
a) restart the camera
b) restart zm
James Wilson
Axel
Post by Axel »
Hello again.
Yes. Today i restart cam and entire system.
Now it works a while before the cam will be hang.
Maybe its the cam/release 4.22?
Anyone have a newer? Beta?
Greetings,
Axel
Axel
Post by Axel »
Incredible!
TODAY morning, i talk to the support - Line and they suggest changeless, no newer firmware or bata is available.
30 minutes later, i receive a link from axis, with the new release 4.40.
Hooray! Now i try it first.
Will post the result after try out.
Greetings,
Axel
zoneminder
Site Admin
Post by zoneminder »
Good, is this firmware for the 207 only? Let us know how you get on.
Phil
Axel
Post by Axel »
Hi Folks.
After updating the 207 with 4.40, the cam works without any problems since 4 Days.
Now i try to replace two of the 2100 by 207, because the problems with the 2100 and 1.22.2 will continue.
Because i cannot longer operate 2 systems, i must switch of the older system this week.
Two other 2100 on the 1.22.2 exist and i would be gratefull for any hints.
Thanks to the community for all the help,
Axel
anachrnism
Post by anachrnism »
I know this is an old post, however I came across a similar problem with my install, and stumbled across this thread.
I eventually found my problem. I had my 207's and the server set to auto-negotaite speed and duplex. I had everything hooked up to a netgear hub (so half duplex), and saw a _lot_ of zmc restarts from my 8 cameras. I think their could have been problems when devices re-negotiated. Swapping the hub for a switch (full duplex goodness), and my problems went away.
Might work with the hub if everything is set to half duplex, no auto-neg, but was quicker to use the switch than change each camera. :-)
zoneminder
Site Admin
Thanks for posting this, I would never have thought of that. I thought everything was full duplex nowadays :shock:
Phil
