zmc_dvideo1[2922]: WAR [Buffer overrun at index 52, slow down capture, speed up analysis or increase ring buffer size]
I raised Image Buffer Size to 60, Warm up frames to 25, pre and post buffers to 10 - No success.
I lowered the Max FPS to as far as 1 but no success only took longer to get this buffer overrun.
CPU is running at like 0.05 so it shouldnt have any problems if it tried.
I reloaded all the default settings into the DB to see if i had changed something i shouldn't but still the same.
Does anyone have a good idea what i shall try next, something is seriusly wrong, im starting to think it might be the hardware that has broke down.
Some HW info:
CPU: 1,6Ghz Athlon
Memory: 512Mb
VideoCard: Hauppauge BT878 WinTV @ 320x240 (running grayscale to save memory)
Machine is running Fedora 4 with no other tasks beside running ZM.
Some help is greatly appreciated now, Thank you
