Hi!
Run ZM on PC Celeron 1000 MHz/256+128MB.
Frame rate probing 1-2-3-4-5-6-7-8-9-10 set.
Frame rate ist 1-2 fps now and modect.
System STOPPED every 10-40 hours - reset only!
If modect ist off server stopped every 4-5 day.
If all zm process off system works normally (tested 12 day non-stop).
What ist not good?
zmu -d /dev/video -q -v says:
Video Capabilities
Name: BT878 video (GrandTec Multi Cap
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 4
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 352
Height: 288
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 28000
Hue: 32768
Colour :38000
Contrast: 32768
Whiteness: 0
Channel 0, 1 , 2 and 3 Attributes
Name: Composite0 /1 /2 /3
Channel: 0 /1 /2/ 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Thu 5th Oct, 5:48pm ZoneMinder Console - Running - v1.22.2
Load: 0.45 / Disk: 21% 4 Monitors
Logged In As xxxxx, configured for low bandwidth
/var/log/boot.log:
Oct 5 13:48:30 video httpd: httpd startup succeeded
Oct 5 13:48:32 video rc: Starting kheader: succeeded
Oct 5 13:48:32 video zm: Starting ZoneMinder:
Oct 5 13:48:45 video zm: ^[[65G
Oct 5 13:48:45 video zm: [^[[1;32m
Oct 5 13:48:45 video zm: OK
Oct 5 13:48:45 video rc: Starting zm: succeeded
Oct 5 15:16:54 video partmon: Checking if partitions have enough free diskspace:
Oct 5 15:16:54 video partmon: ^[[65G
Oct 5 15:16:54 video partmon: [^[[1;32m
Oct 5 15:16:54 video partmon: OK
Oct 5 15:16:54 video partmon: ^[[0;39m
Oct 5 15:16:54 video rc: Starting partmon: succeeded
Oct 5 15:16:57 video cups: cupsd startup succeeded
Oct 5 15:17:00 video alsa: succeeded
Oct 5 15:17:01 video xfs: xfs startup succeeded
Oct 5 15:17:12 video httpd: httpd startup succeeded
Oct 5 15:17:14 video rc: Starting kheader: succeeded
Oct 5 15:17:14 video zm: Starting ZoneMinder:
Oct 5 15:17:27 video zm: ^[[65G
Oct 5 15:17:27 video zm: [^[[1;32m
Oct 5 15:17:27 video zm: OK
Oct 5 15:17:27 video rc: Starting zm: succeeded
/var/log/syslog:
Oct 5 14:34:57 video zma_m1[4233]: INF [Sklep-1: 4228 - Gone into alarm state]
Oct 5 14:34:58 video zma_m1[4233]: INF [Sklep-1: 4229 - Gone into alert state]
Oct 5 14:34:58 video zma_m1[4233]: INF [Sklep-1: 4230 - Gone back into alarm state]
Oct 5 14:35:00 video zma_m4[4383]: INF [Centrum: 3975 - Left alarm state (1534) - 49(29) images]
Oct 5 14:35:04 video zmfilter[4255]: INF [Executing '/usr/lib/zm/bin/zmeventdump 4/1532']
Oct 5 14:35:04 video zmfilter[4255]: INF [Executing '/usr/lib/zm/bin/zmeventdump 2/1533']
Oct 5 14:35:04 video zmfilter[4255]: INF [Executing '/usr/lib/zm/bin/zmeventdump 4/1534']
Oct 5 14:35:04 video zmfilter[4255]: INF [Executing '/usr/lib/zm/bin/zmeventdump 1/1535']
Oct 5 14:35:08 video zma_m1[4233]: INF [Sklep-1: 4245 - Gone into alert state]
Oct 5 14:35:11 video zma_m1[4233]: INF [Sklep-1: 4250 - Left alarm state (1536) - 27(16) images]
Oct 5 14:35:13 video zma_m4[4383]: INF [Centrum: 3995 - Gone into alarm state]
Oct 5 14:35:14 video zma_m4[4383]: INF [Centrum: 3996 - Gone into alert state]
Oct 5 14:35:14 video zma_m1[4233]: INF [Sklep-1: 4254 - Gone into alarm state]
Oct 5 14:35:15 video zmc_dvideo0[4375]: INF [Sklep-1: 4000 - Capturing at 1.52 fps]
Oct 5 14:35:15 video zmc_dvideo0[4375]: INF [Sklep-2: 4000 - Capturing at 1.52 fps]
Oct 5 14:35:16 video zmc_dvideo0[4375]: INF [Magazyn: 4000 - Capturing at 1.52 fps]
Oct 5 14:35:16 video zmc_dvideo0[4375]: INF [Centrum: 4000 - Capturing at 1.52 fps]
Oct 5 14:35:17 video zma_m4[4383]: INF [Centrum: 4000 - Processing at 1.52 fps]
Oct 5 14:35:17 video zma_m4[4383]: INF [Centrum: 4001 - Left alarm state (1537) - 11(1) images]
Oct 5 14:35:18 video zma_m1[4233]: INF [Sklep-1: 4260 - Gone into alert state]
Oct 5 14:35:19 video zma_m1[4233]: INF [Sklep-1: 4262 - Gone back into alarm state]
Oct 5 14:35:25 video zma_m1[4233]: INF [Sklep-1: 4270 - Gone into alert state]
Oct 5 14:35:28 video zma_m1[4233]: INF [Sklep-1: 4275 - Left alarm state (1538) - 26(14) images]
Oct 5 15:16:54 video syslogd 1.4.1: restart.
Oct 5 15:16:54 video kernel: klogd 1.4.1, log source = /proc/kmsg started.
Oct 5 15:16:54 video kernel: Inspecting /boot/System.map-2.6.16.17.rdm1.smp
Oct 5 15:16:54 video kernel: Loaded 22949 symbols from /boot/System.map-2.6.16.17.rdm1.smp.
Oct 5 15:16:54 video kernel: Symbols match kernel version 2.6.16.
Oct 5 15:16:54 video kernel: No module symbols loaded - kernel modules not enabled.
Oct 5 15:16:54 video kernel: Linux version 2.6.16.17.rdm1.smp (ross@sentrix.local.domain) (gcc version 4.0.1 (4.0.1-5mdk for Mandriva Linux release 2006.0)) #1 SMP Sat May 27 22:19:23 PDT 2006
Oct 5 15:16:54 video kernel: BIOS-provided physical RAM map:
Oct 5 15:16:54 video kernel: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
Oct 5 15:16:54 video kernel: BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
Oct 5 15:16:54 video kernel: BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Oct 5 15:16:54 video kernel: BIOS-e820: 0000000000100000 - 0000000017000000 (usable)
Oct 5 15:16:54 video kernel: BIOS-e820: 00000000fffc0000 - 0000000100000000 (reserved)
Oct 5 15:16:54 video kernel: 0MB HIGHMEM available.
Oct 5 15:16:54 video kernel: 368MB LOWMEM available.
Oct 5 15:16:54 video kernel: On node 0 totalpages: 94208
Oct 5 15:16:54 video kernel: DMA zone: 4096 pages, LIFO batch:0
Oct 5 15:16:54 video kernel: DMA32 zone: 0 pages, LIFO batch:0
Oct 5 15:16:54 video kernel: Normal zone: 90112 pages, LIFO batch:31
Oct 5 15:16:54 video kernel: HighMem zone: 0 pages, LIFO batch:0
Oct 5 15:16:54 video kernel: DMI 2.3 present.
/var/log/zm/zmdc.log:
Oct 5 14:35:58 video zma_m1[4233]: INF [Sklep-1: 4320 - Gone into alarm state]
Oct 5 14:36:04 video zmfilter[4255]: INF [Executing '/usr/lib/zm/bin/zmeventdump 1/1536']
Oct 5 14:36:04 video zmfilter[4255]: INF [Executing '/usr/lib/zm/bin/zmeventdump 4/1537']
Oct 5 14:36:05 video zmfilter[4255]: INF [Executing '/usr/lib/zm/bin/zmeventdump 1/1538']
Oct 5 14:36:05 video zma_m4[4383]: INF [Centrum: 4074 - Gone into alarm state]
Oct 5 14:36:06 video zma_m1[4233]: INF [Sklep-1: 4333 - Gone into alert state]
Oct 5 14:36:09 video zma_m1[4233]: INF [Sklep-1: 4338 - Left alarm state (1539) - 23(13) images]
Oct 5 14:36:09 video zma_m2[4239]: INF [Sklep-2: 4338 - Gone into alarm state]
Oct 5 14:36:10 video zma_m2[4239]: INF [Sklep-2: 4339 - Gone into alert state]
Oct 5 14:36:11 video zma_m4[4383]: INF [Centrum: 4082 - Gone into alert state]
Oct 5 14:36:11 video zma_m4[4383]: INF [Centrum: 4083 - Gone back into alarm state]
Oct 5 14:36:11 video zma_m1[4233]: INF [Sklep-1: 4341 - Gone into alarm state]
Oct 5 14:36:12 video zma_m1[4233]: INF [Sklep-1: 4342 - Gone into alert state]
Oct 5 14:36:12 video zma_m4[4383]: INF [Centrum: 4085 - Gone into alert state]
/var/log/messages:
Oct 5 14:34:55 video zma_m4[4383]: INF [Centrum: 3968 - Gone back into alarm state]
Oct 5 14:34:57 video zma_m4[4383]: INF [Centrum: 3970 - Gone into alert state]
/var/log/syslog: (if normal pc restart)
Oct 5 15:50:09 video zma_m4[4251]: INF [Centrum: 3011 - Left alarm state (1590) - 11(1) images]
Oct 5 15:50:11 video zma_m4[4251]: INF [Centrum: 3015 - Gone into alarm state]
Oct 5 15:50:12 video zma_m4[4251]: INF [Centrum: 3016 - Gone into alert state]
Oct 5 15:50:15 video zma_m4[4251]: INF [Centrum: 3021 - Left alarm state (1591) - 11(1) images]
Oct 5 15:50:38 video zmfilter[4255]: INF [Executing '/usr/lib/zm/bin/zmeventdump 4/1590']
Oct 5 15:50:38 video zmfilter[4255]: INF [Executing '/usr/lib/zm/bin/zmeventdump 4/1591']
Oct 5 15:51:20 video shutdown[5088]: shutting down for system reboot
Oct 5 15:51:20 video init: Switching to runlevel: 6
Oct 5 15:51:22 video zm: Stopping ZoneMinder:
Oct 5 15:51:22 video zmpkg[5139]: INF [Command: stop]
Oct 5 15:51:22 video sudo: root : TTY=console ; PWD=/var/www/html/zm ; USER=apache ; COMMAND=/bin/true
Oct 5 15:51:22 video sudo: root : TTY=console ; PWD=/var/www/html/zm ; USER=apache ; COMMAND=/usr/lib/zm/bin/zmdc.pl check
Oct 5 15:51:23 video sudo: root : TTY=console ; PWD=/var/www/html/zm ; USER=apache ; COMMAND=/usr/lib/zm/bin/zmdc.pl shutdown
Oct 5 15:51:23 video zmdc[4206]: INF ['zma -m 3' stopping at 06/10/05 15:51:23]
Oct 5 15:51:23 video zma_m3[4245]: INF [Got signal (Terminated), exiting]
Oct 5 15:51:23 video zmdc[4206]: INF ['zma -m 3' exited normally]
Oct 5 15:51:23 video zmdc[4206]: INF ['zma -m 2' stopping at 06/10/05 15:51:23]
Oct 5 15:51:23 video zma_m2[4239]: INF [Got signal (Terminated), exiting]
Oct 5 15:51:23 video zmdc[4206]: INF ['zma -m 2' exited normally]
Oct 5 15:51:23 video zmdc[4206]: INF ['zmc -d /dev/video0' stopping at 06/10/05 15:51:23]
Oct 5 15:51:23 video zmc_dvideo0[4229]: INF [Got signal (Terminated), exiting]
Oct 5 15:51:23 video zmc_dvideo0[4229]: ERR [Sync failure for frame 6 buffer 6(1): Interrupted system call]
Oct 5 15:51:23 video zmdc[4206]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
Oct 5 15:51:23 video zmdc[4206]: INF ['zmaudit.pl -c' stopping at 06/10/05 15:51:23]
Oct 5 15:51:23 video zmdc[4206]: INF ['zmaudit.pl -c' crashed, signal 14]
Oct 5 15:51:23 video zmdc[4206]: INF ['zma -m 1' stopping at 06/10/05 15:51:23]
Oct 5 15:51:23 video zma_m1[4233]: INF [Got signal (Terminated), exiting]
Oct 5 15:51:23 video zmdc[4206]: INF ['zma -m 1' exited normally]
Oct 5 15:51:23 video zmdc[4206]: INF ['zmfilter.pl ' stopping at 06/10/05 15:51:23]
Oct 5 15:51:23 video zmdc[4206]: INF ['zmfilter.pl ' crashed, signal 14]
Oct 5 15:51:23 video zmdc[4206]: INF ['zmwatch.pl ' stopping at 06/10/05 15:51:23]
Oct 5 15:51:23 video zmdc[4206]: INF ['zmwatch.pl ' crashed, signal 14]
Oct 5 15:51:23 video zmdc[4206]: INF ['zma -m 4' stopping at 06/10/05 15:51:23]
Oct 5 15:51:23 video zma_m4[4251]: INF [Got signal (Terminated), exiting]
Oct 5 15:51:23 video zmdc[4206]: INF ['zma -m 4' exited normally]
Oct 5 15:51:33 video zmdc[4206]: INF [Server shutdown at 06/10/05 15:51:33]
Oct 5 15:51:33 video zm: ^[[65G
Oct 5 15:51:33 video zm: [^[[1;32m
Oct 5 15:51:33 video zm: OK
Oct 5 15:51:33 video rc: Stopping zm: succeeded
Oct 5 15:51:34 video httpd: httpd shutdown succeeded
Oct 5 15:51:34 video ntpd[3844]: ntpd exiting on signal 15
Oct 5 15:51:34 video ntpd: ntpd shutdown succeeded
Oct 5 15:51:34 video webmin: Stopping Webmin server in /usr/libexec/webmin
Oct 5 15:51:34 video rc: Stopping webmin: succeeded
Oct 5 15:51:34 video xfs[3662]: terminating
Oct 5 15:51:35 video xfs: xfs shutdown succeeded
Oct 5 15:51:35 video rc: Stopping kheader: succeeded
Oct 5 15:51:35 video rc: Stopping partmon: succeeded
Oct 5 15:51:35 video sshd: stop succeeded
Oct 5 15:51:35 video rc: Stopping sshd: succeeded
Oct 5 15:51:35 video xinetd[3873]: Exiting...
Oct 5 15:51:35 video xinetd: xinetd shutdown succeeded
Oct 5 15:51:35 video crond: crond shutdown succeeded
Oct 5 15:51:35 video cups: cupsd shutdown succeeded
Oct 5 15:51:36 video haldaemon: haldaemon -TERM succeeded
Oct 5 15:51:36 video mDNSResponder: mDNSResponder shutdown succeeded
Oct 5 15:51:36 video messagebus: messagebus -TERM succeeded
Oct 5 15:51:36 video nifd: nifd shutdown succeeded
Oct 5 15:51:37 video alsa: succeeded
Oct 5 15:51:39 video kernel: gameport: kgameportd exiting
Oct 5 15:51:39 video alsa: succeeded
Oct 5 15:51:39 video kernel: Kernel logging (proc) stopped.
Oct 5 15:51:39 video kernel: Kernel log daemon terminating.
Oct 5 15:51:40 video exiting on signal 15
Oct 5 15:53:11 video syslogd 1.4.1: restart.
Oct 5 15:53:11 video kernel: klogd 1.4.1, log source = /proc/kmsg started.
Oct 5 15:53:11 video kernel: Inspecting /boot/System.map-2.6.16.17.rdm1.smp
Oct 5 15:53:11 video partmon: Checking if partitions have enough free diskspace:
Oct 5 15:53:12 video kernel: Loaded 22949 symbols from /boot/System.map-2.6.16.17.rdm1.smp.
Oct 5 15:53:12 video kernel: Symbols match kernel version 2.6.16.
Thank you for any suggestions!
very sorry for my terrible english
System stopped - hard reset only!
- zoneminder
- Site Admin
- Contact:
It may be worth running a memory test on your system to check your RAM is ok, as that tends to be the most common reason for sudden lockups. Also perhaps switch ZM off and run burnMMX or similar to thrash your processor in case your system is overheating. Using Modect requires more CPU than not.
Phil
- Carbide_tipped
Put money on the capture card!
Had a BT848 card in my machine that was causing lock-ups. I would see a kernel dump caused by it. You can test this theory by just disabling the camera and restarting ZM. You should see that the zmc /dev/video0 is not running. Also hooking a monitor up to it when it crashes and seeing what caused the kernel crash.
