I am using the distro on a computer hidden in a utility room and connected to my big screen TV in the living room - allowin me to check out the cams as well as surf/read email etc. I run a USB-cable and a DVI/cable trough the wall to the utrility room.
Now my problem is that my RF wireles keyboard/mouse combo dont work with the distro or with any Linux out of the box (there is however a fix that can be used see
http://www.tcnj.edu/~tolboom2/globlink_rf88.html) that either require a patch to be applied (but I dont know how to rebuild the distro or drivers in general) or that a program be built that will send some sequences to the keyboard using the usbfs before the keyboard driver is loaded (but I have no clue how to run a program before the keyboard driver is loaded).
By downloading the development package from Fedora I have managed to build the little program but as I said how to run it at the right time? Is usbfs by the way suported in the distro?
Any sugestions what is the easiest way to make this work???
Right now I have everything else working - latest NVIDIA driver allowed me to watch zone minder in nice 1280x720 native panel resolution using a 6200 card! Just want tgo get rid of the long keyboard cable and regular keyboard I use right now...
Best Regards
Trist
