i have i employee
who i think is stealing off us
is there a way to put a usb cam hidden in a xp box and with software
hidden to the user, stream the image back to the office zm box
as a ip camera or other way
there is to much rf for wireless cams and wiring
thanks
marty
can i question
can i question
I donated have YOU?
A search for "windows usb cam" turns up a few results.
http://www.zoneminder.com/forums/viewto ... ws+usb+cam
Regards,
Corey
Regards,
Corey
legally if you hgave na internal issue here in the uk you need police approval to use coverts without signs.
But why dont you just put a camera outside or in reception etc and a couple of signs saying covert cctv operating throughout
if you dont do it properly the evidence 'may' be inadmissable but if theyu plead guilty it wont matter
James Wilson
btw im thinking of extending the screen capture cam to add this as i have to some live video feeds in zm4ms for something im doing so maybe youd like to test this
James Wilson
