Zoneminder/CTU core CD distro
dpalin
Post by dpalin »
jameswilson wrote:yum wont update you past 1.21.4 at the mo. As its not deemed as stable by Corey. YOu can manulay rpm it from one of his newer rpm's if you wish
My dumb question of the day :-)
Where are the RPM's, I don't see them in the download's. Not trying to be lazy but am missing them...
Doug
jameswilson
Post by jameswilson »
James Wilson
cordel
Post by cordel »
Opp's,
My bad was that I had put the rpm's in the Extra-RPMS repo. What I forgot is that it is disabled by default in the distro. you have to do :
yum --enablerepo Extra-RPMS update
I have now added it to the updates repo so it should work for everyone with just a yum update.
Tboy
Trouble updating to 1.22
Post by Tboy »
When trying to update via yum I keep getting this..
"http://download.computerntelecom.com/pu ... t.i386.rpm: [Errno -1] Header is not complete.
Trying other mirror.
Error: failure: os/zm-1.22.2-0.2.fc.root.i386.rpm from ctu-updates-released: [Errno 256] No more mirrors to try."
What's up with that?
cordel
Post by cordel »
I updated the repo header files. Try giving it a shot again.
There are also no mirrors. One company offered and synced everything from my server then closed access :evil: Not very nice. So My server is it.
Regards,
Corey
Tboy
Post by Tboy »
It got farther this time... Here the details. Still hung at the end.
[root@localhost Desktop]# yum update
Setting up Update Process
Setting up Repos
ctu-updates-released 100% |=========================| 951 B 00:00
ctu-base 100% |=========================| 951 B 00:00
Reading repository metadata in from local files
primary.xml.gz 100% |=========================| 97 kB 00:02
MD Read : ################################################## 204/204
ctu-update: ################################################## 204/204
ctu-base : ################################################## 633/633
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package cpp.i386 0:3.4.4-2.fc3 set to be updated
---> Package php.i386 0:4.3.11-2.8 set to be updated
---> Downloading header for zm to pack into transaction set.
zm-1.22.2-0.2.fc.root.i38 100% |=========================| 41 kB 00:02
---> Package zm.i386 0:1.22.2-0.2.fc.root set to be updated
---> Package glibc.i686 0:2.3.6-0.fc3.1 set to be updated
---> Package php-pear.i386 0:4.3.11-2.8 set to be updated
---> Package php-mysql.i386 0:4.3.11-2.8 set to be updated
---> Package mkinitrd.i386 0:4.1.18.1-1 set to be updated
---> Package ffmpeg.i386 0:0.4.9-0.3.20051207.2.fc3.CTU set to be updated
---> Package glibc-common.i386 0:2.3.6-0.fc3.1 set to be updated
---> Package kernel.i686 0:2.6.12-1.1381_FC3 set to be installed
---> Package perl.i386 3:5.8.5-20.FC3 set to be updated
---> Package libgcc.i386 0:3.4.4-2.fc3 set to be updated
--> Running transaction check
--> Processing Dependency: perl-X10 for package: zm
--> Processing Dependency: perl(X10::ActiveHome) for package: zm
--> Processing Dependency: libpostproc.so.0.0.1 for package: ffmpeg
--> Restarting Dependency Resolution with new changes.
---> Downloading header for perl-X10 to pack into transaction set.
perl-X10-0.03-1.noarch.rp 100% |=========================| 8.0 kB 00:00
---> Package perl-X10.noarch 0:0.03-1 set to be updated
---> Downloading header for ffmpeg-libpostproc to pack into transaction set.
ffmpeg-libpostproc-0.4.9- 100% |=========================| 7.4 kB 00:00
---> Package ffmpeg-libpostproc.i386 0:0.4.9-0.3.20051207.2.fc3.CTU set to be updated
--> Processing Dependency: perl(Time::ParseDate) for package: perl-X10
--> Processing Dependency: perl(Astro::SunTime) for package: perl-X10
--> Processing Dependency: pkgconfig for package: ffmpeg-libpostproc
---> Downloading header for perl-Astro-SunTime to pack into transaction set.
perl-Astro-SunTime-0.01-F 100% |=========================| 2.3 kB 00:00
---> Package perl-Astro-SunTime.noarch 0:0.01-FC3 set to be updated
---> Downloading header for perl-Time-modules to pack into transaction set.
perl-Time-modules-2003.11 100% |=========================| 3.7 kB 00:00
---> Package perl-Time-modules.noarch 0:2003.1126-1 set to be updated
--> Finished Dependency Resolution
Error: Missing Dependency: pkgconfig is needed by package ffmpeg-libpostproc
cordel
Post by cordel »
Use this:
yum --enablerepo=updates-released --enablerepo=base [install | update ] zm
Regards,
Corey
jameswilson
Corey i can mirror on my servers, i have 2 so you could have access to one of em i presume i could just schedule a wget every night or something from you? pm if you like, i promise i wont close you off!!
James Wilson
cordel
Post by cordel »
Thanks James,
When I'm ready I'll send you the info :)
I restructuring things as I want to do this a bit different this time. ;)
Just because of inconsistancies like above.
Regards,
Corey
Tboy
Post by Tboy »
Ok, call me retarded. What am I doing wrong? That isnt working either.
cordel
Post by cordel »
Your not retarded... Redhats mirror list is down... I'll see if I can get the package on my repo.
Stay tuned... same bat station.... I'll have it up soon.
Regards,
Corey
cordel
Post by cordel »
should be good to go now.
Corey
Tboy
Post by Tboy »
Whew! I thought I was destined to ride the short bus to work...
It worked. I'm good to go now. Many thanks for your help.
When's the ctu fc5 going to be released?
cordel
Post by cordel »
It's not ever going to be released. I just dumped it off my drive.... FC6 released yesterday :D
So I'm going to work on that, but I am starting over so it may be a while.
Regards,
Corey
arielb27
Post by arielb27 »
Would it not be better to do the CTU on a released Distro that is stable?
Like CentOS Which is the GPL release of RH EL 4.
I have had so many issues with Fedore release. It's where everyone test there new stuff. And I don't feel it's something to use as a release Distro but something to play and do testing with only.
Thank you.
