No Pictures
No Pictures
I have ”ZM4MS 2.81 Beta” up and running on Windows XP, setup MYSQL access works I see all events “zm 1.22.2” my problem is I can’t see any pictures in playback or live I do see FPS coming across. It works when I put in a camera address. The paths are correct. Is their something missing?
when you say it works when you put in a camera address do you mean url? and then turn on url mode? or something else
James Wilson
the default path is for the 2006 live cd only if your using another distro or your apache is setup differently it will fail. Is you box public?
James Wilson
if you make your zm server and pm the details i will send you a correct path statement for zm4ms
James Wilson
i cant get the https path to work with zm as the cert is not from a trusted authority. Do you have a non https ie http available for me to test against
James Wilson
Well i have set camera 36 up in the folloeing way usint the default path
ip = skyeye.dynalias.com
port = blank or :80 (you must include the ':' )
mon = 1
under paths
path = /cgi-bin/nph-zms
data type = https:// (changed from http://)
I also installed the cert and all is fine.
mon = 1
under paths
James Wilson
lol, finally!
James Wilson
