I have ZM 1.22.2 installed and I have absolutely no problem accessing it from my LAN.
Unoforuntely, I cannot access ZM from WAN. The connection times out.
I am using port forwarding thru DynDns using a LinkSys router to connect to a Windows back end server and to attempt to connect to ZM.
I believe my ISP is blocking inbound connections to port 80 which may be the cause of my problem. Thus, is there any way to change the port that ZM is listening on?
Thanx
problem accessing ZM thru WAN
: port 80 blocked
or if you dont want to mess around with the apache config, you can just use https://DYNDNSADDRESS.com as most ISP dont block secure http, and just port 80
works for me on adelphia
