Hiya
Could anyone who has the Kodicom 4400R confirm whether or not it comes with daughter boards to enable at least a further 8 composite inputs?
I have found an international supplier of the card to the UK for $200, not figured out the shipping yet, is this a reasonable price?
Was looking at the Linux Media Card, but the only additional feature it appears to have is alarm outputs, which I don't think I will find myself ever using, and it's 1/3 more expensive at $299, any other reason why I should consider the LML card?
Many thanks
James
Actually, also, I'd like to capture sound too, are there any alternative boards on the same level which have this feature?
Does zoneminder even support sound capture?
Contents of Kodicom 4400R package?
It depends on the supplier whether the board comes with the daughter cards and some charge extra for them.
The board does not have connectors to interface sound to yet it is capable ( a little soldering involved to capture sound through that board).
Sorry, but at this time zm does not handle capturing sound. It is already on the wish list but I suspect that it might be some time before we see it.
Regards,
Corey
Regards,
Corey
