Windows Live Viewer..27-11-05 Now Complete Frontend for ZM!!
jameswilson
Post by jameswilson »
glad its running, can you detail what you do to replicate the error so I can try, and then fix please?
James Wilson
BobS0327
Post by BobS0327 »
I have a 4 camera view, two of which are being used. I select the Menu button and check Auto Cycle Current View. I let the views synchronise for a while until the Menu button reappears. The next time I click on the Menu button, the menu options do NOT appear but the views keep on synchronising and eventually the unhandled exception message appears.
jameswilson
i will test when i get home tonight. Thanks
PS if you can could you duplicate your settings for cam 3 and 4 as in 1 and 2, and use a 4 way view on sequence. I only ask i havnt tested cycle on 2 way view.
how many cams do you have setup (if its 4 or more ignore above)
James Wilson
BobS0327
Post by BobS0327 »
I have duplicated my two cameras in view 3 and 4 and still have the same problem.
jameswilson
you found a bug, well done i will fix it for the next relese
James Wilson
R2D2
Post by R2D2 »
R2D2 wrote:
jameswilson wrote:you need to remove skip-networking from your mysql settings.
There is a zm4ms howto on the wiki that covers this
i don't have a entry like "skip-networking" in my /etc/sysconfig/mysqld
# Use the Instance Manager by default. Set to "1" to use the old mysqld_safe script.
use_mysqld_safe="0"
# (oe) set TMPDIR and TMP environment variables
TMPDIR="${datadir}/.tmp"
TMP="${TMPDIR}"
Do you have a solution for this problem?
Solved
The Entry skip-networking is in Mandiva 2007 free Edition not in /etc/sysconfig/mysqld rather in /etc/my.cnf
# Don't listen on a TCP/IP port at all. This can be a security enhancement,
# if all processes that need to connect to mysqld run on the same host.
# All interaction with mysqld must be made via Unix sockets or named pipes.
# Note that using this option without enabling named pipes on Windows
# (via the "enable-named-pipe" option) will render mysqld useless!
# skip-networking
jameswilson
lol well there is in 2006. Try downloading the mysql tools for windows and diagnose the connection that way. Also do you have a firewall on port 3306
James Wilson
R2D2
Post by R2D2 »
you was faster.........
Problem is solved
R2D2
Post by R2D2 »
I've had a Errormessage like this:
i solved the problem with:
# mysqladmin --no-defaults -u root version
# mysqladmin reload
maybe helpful for others.....
drakkan
Post by drakkan »
Hi James,
I would like contribute an italian translation for zm4ms, can explain how to do this?
thanks
drakkan
jameswilson
no easy way to be honest as there is no support for other languages. I will languages as people offer. I will get zm4ms ready for multi languge over the next few releases, once ready i will post a request for translations. Then ill add the languages that are made available
James
James Wilson
zoneminder
Site Admin
Post by zoneminder »
Ross has suggested that perhaps the Live Viewer needs it's own forum. I am easy either way on this but have created a Poll if anyone would like to express an opinion on the subject.
Phil
roadie5
Post by roadie5 »
ZM4MS sure looks like a nice app. I'm having trouble getting connected to my ZM server though.
I've turned on authentication on the ZM and can log in as admin/admin. The os is a fresh install of Fedora 5 and the firewall has been disabled. My client is WinXP w/ IE which can bring up the ZM page fine as a 'https://192.168.2.3/zm/index.php' link.
When I run the Live Viewer and I log in as admin/admin, I get the 4-screen view and nothing. The first line in the config is filled in with 192.168.2.3 and '1' for the camera number. URL is not checked.
What could I be doing wrong? My ZM install is the latest ver (1.22.2) compiled from source. MySQL access shouldn't matter just to bring up the views, right?
Thank you for your help.
roadie5
Post by roadie5 »
Hmmmm....
I can connect to my ZM-server using a live-CD install of ZM which is running under port 80 (no ssl) and it works!
I also tried using port 443 with the ssl install and no-go.
R2D2
Post by R2D2 »
