"make install" does nothing
Barbado
Post by Barbado »
Hello gentlemen,
Iam a Brazilian Java developer trying to install ZoneMinder 1.22.2 along with MySQL within a stable Debian (Sarge) box, kernel v. 2.6.16.
Using packages apache2 and php5.
Please note that I'm not used to databases. I'm sorry if I skipped some essential step.
Here is the sequence used untill this problem appeared:
# echo kernel.shmmax = 134217728 >> /etc/sysctl.conf
Since I already had MySQL installed with proper root user password defined, I logged in:
# mysql -u root -p
> grant select,insert,update,delete on zm.* to 'zmuser'@localhost identified by '<my_root_passwd>';
> quit
# mysqladmin reload -u root -p
And, inside the following directory,
ZoneMinder-1.22.2# ls
acinclude.m4  ChangeLog    configure     db       install-sh   missing        README       README.rtf  src   zm.conf.in
aclocal.m4    config.h.in  configure.in  depcomp  Makefile.am  mkinstalldirs  README.html  README.txt  TODO
AUTHORS       config.log   COPYING       INSTALL  Makefile.in  NEWS           README.pdf   scripts     web
I provided the following commands:
# ./configure --with-webdir=/var/www/html --with-cgidir=/var/www/cgi-bin
# make install
This last command returns me:
make: *** Without rule for processing `install' target.  Stop.
I know little about make and I would really appreciatte any help.
Thank you very much for your attention.
malarcy
Post by malarcy »
I too am a compete newbie - but I have got ZM up and running - I am using ubuntu dapper - but I don't think that's relevent - looking at your posting I think you have missed something on the .configure line. The howto I used gave it as this:
./configure --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin --with-webuser=www-data --with-webgroup=www-data
HTH
Malarcy
Barbado
Post by Barbado »
started all over again, carefully following README and INSTALL files.
by this time, my configure command was:
# ./configure --with-webdir=/var/www/zm –-with-cgidir=/var/www/cgi-bin –-with-webuser=www-data –-with-webgroup=www-data ZM_DB_HOST=vigilancia
the error returned:
configure: error: C++ preprocessor "/lib/cpp" fails sanity check
any ideas?
malarcy
Post by malarcy »
Guess the c++ compiler isn't installed - seems to be a bit of discussion here....
http://www.linuxquestions.org/questions ... tid=647188
HTH
Malarcy
cordel
Post by cordel »
Make sure you have cpp installed.
[cordel@builder64 ~]$ rpm -q --whatprovides /lib/cpp
cpp-4.1.1-1.fc5
Regards,
Corey
Barbado
Post by Barbado »
Thanks Malarcy and Corey,
think I've passed that level but a new problem has just showed up.
Remembering my configure command:
and this is the new error message I'm receiving:
checking mysql/mysql.h usability... no
checking mysql/mysql.h presence... no
checking for mysql/mysql.h... no
configure: error: zm requires mysql/mysql.h
See, I've already installed package mysql-server.
What's wrong here?
Thank you.
cordel
Post by cordel »
It needs the client and devel. A list of the prerequisites is in the hints and tips topic ZoneMinder Dependencies That may be of some use to you.
Regards,
Corey
Barbado
2 new errors
Post by Barbado »
Ok thank you Corey,
I really appreciate your help.
I'm checking the list you provided to eliminate these new errors I'm receiving. They say my system lacks some stuff but the referred packages are in there.
1st error:
checking pcre/pcre.h usability... no
checking pcre/pcre.h presence... no
I installed both libpcre3-dev and perl packages so I'm a bit confused here.
2nd error
checking whether MD5 is declared... no
configure: error: zm requires openssl/md5.h
Again I have the current openssl package version installed.
cordel
Post by cordel »
Some program requirements have several tests in configure ( to account for the different distros and the differance on where things are placed) so there are three different tests for pcre and all but one should fail. As long as one of the tests pass, your good to go.
Other wise you will have to add the path into configue.
Regards,
Corey
Barbado
make install
Post by Barbado »
my newest error
make install error: now this topic's main subject starts to "make" sense =)
zm_mpeg.cpp:88: error: cannot convert 'AVCodecContext**' to 'AVCodecContext*' in initialization
zm_mpeg.cpp:109: error: 'struct AVCodecContext' has no member named 'frame_rate'
zm_mpeg.cpp:110: error: 'struct AVCodecContext' has no member named 'frame_rate_base'
zm_mpeg.cpp: In member function 'void VideoStream::OpenStream()':
zm_mpeg.cpp:161: error: cannot convert 'AVCodecContext**' to 'AVCodecContext*' in initialization
zm_mpeg.cpp: In destructor 'VideoStream::~VideoStream()':
zm_mpeg.cpp:256: error: cannot convert 'AVCodecContext**' to 'AVCodecContext*' for argument '1' to 'int avcodec_close(AVCodecContext*)'
zm_mpeg.cpp: In member function 'double VideoStream::EncodeFrame(uint8_t*, int, bool, unsigned int)':
zm_mpeg.cpp:303: error: cannot convert 'AVCodecContext**' to 'AVCodecContext*' in initialization
make[1]: ** [zm_mpeg.o] Erro 1
make[1]: Leaving directory `/home/mbarbado/ZoneMinder-1.22.2/src'
make: ** [install-recursive] Erro 1
help?
jameswilson
Post by jameswilson »
see wiki re ffmpeg patch
James Wilson
Barbado
Post by Barbado »
Shall I just download zm-1.22.2-ffmpeg.patch into ZM's directory and rerun make install? Is it the correct thing to do?
jameswilson
Sorry mate i dont know i only use rpm's
James Wilson
zoneminder
Site Admin
Post by zoneminder »
No, follow the instructions in the Patches section at http://www.zoneminder.com/wiki/index.php/Patches
Phil
Barbado
Cambozola now
Post by Barbado »
Thanx again,
about Cambozola:
I need to put it in the web directory I specified in my ./configure command, right?
In my case,
By that time, do I have to rebuild and reinstall ZM?
