cordel wrote:It would be more helpful to either grant access to your zm box or forward a port to the camera so we (James or myself) can do the digging.
As I was glancing through the post (Like usual
) I thought you might have provided access to the camera and not a file you captured and placed on a apache server. Not very helpful to us to help you.
Also as stated before, if zmc can not get an image... then there is nothing for zms to stream.
You can enable debug under the debug tab in options:
Set the
ZM_EXTRA_DEBUG_TARGET = _zmc to limit your debug only to the zmc component and _zms for the zms component.
Have you checked your firmware version?
Latest on gadspot NC800 IP Networking Camera Firmware Update V4.0f
Regards,
Corey
I tried to go with the most simple route possible. My install of ZM cannot grab a single JPEG from the hard drive, so there's definitely a problem with the installation. The fact that two other people *CAN* access the JPEG without a problem provided the proof I needed to determine this. For that, I thank you.
I'm still trying to work out getting portforwarding to work behind a machine that is already portforwarding. I have a router that is forwarding ports to the ZoneMinder machine, so now I need to forward ports from the ZoneMinder machine to the camera.
I've enabled the extra debugging for zms and changed the debug level to 9. If zms is having a problem, I WILL find the source of it. Thank you for pointing me in the correct direction.
I e-mailed GadSpot support a few days ago inquiring about an updated FirmWare. The latest firmware for my camera V3.1f 10/27/05, according to
http://www.gadspot.com/information.php?info_id=11. Where did you find 4.0f??
EDIT 0:
OK, I've gotten the chance to test out this log. Here's what I've got so far, at debug level 1:
11/05/06 19:15:58.634366 zms[15565].INF-zm_debug.c/304 [New Debug Level = 1, New Debug Log = /tmp/zm_debug.log.15565]
11/05/06 19:15:58.635892 zms[15565].DB1-zms.cpp/84 [Query: mode=jpeg&monitor=1&scale=100&maxfps=5&user=admin&rand=1162772151]
11/05/06 19:15:58.636721 zms[15565].INF-zm_user.cpp/140 [Authenticated user 'admin']
11/05/06 19:15:58.639664 zms[15565].DB1-zm_monitor.cpp/1871 [Got 1 monitors]
11/05/06 19:15:58.642146 zms[15565].DB1-zm_monitor.cpp/235 [monitor purpose=0]
11/05/06 19:15:58.642579 zms[15565].DB1-zm_monitor.cpp/242 [shm.size=2304964]
11/05/06 19:15:58.642941 zms[15565].ERR-zm_monitor.cpp/290 [Shared memory not initialised by capture daemon]
EDIT 1:
I found 4.0f:
http://www.gadget-spot.co.uk/downloads.php
It seems as though GadSpot's non-UK site is deficient and not updated often. Someone from GadSpot might want to look into this.
