Is possible exclude cats, dogs ecc... from alarm?
drakkan
Post by drakkan »
Maybe I'm asking an hard question ...
In my garden I have two dogs, when I use motion detect the dogs alarm zoneminder, there is a way to exclude the dogs from the alarms?
thanks
drakkan
cordel
Post by cordel »
You can increase your mins for blob/filtered/alarmed (risk not catching things you may want)
Best option is to place the camera lower (3 to 4 feet from the ground) so that it will look above the animals but still view the area you want (minus the ground) if posible.
Regards,
Corey
Flash_
Post by Flash_ »
Also setting the zone so it doesn't cover the dogs if they're restricted to only part of it can work.
