Best Linux Distribution for Zoneminder
gola10
Post by gola10 »
I has been using Zonemonder for 3 week installed from the Mandriva 2006 Livecd. There has been problems but has solve most of them thanks to the information on this forum.
Now i want to assemble a computer to be a zoneminder server. I would like to install only what is needed to run zoneminder. It should handle 8 and maybe 16 cameras. I was wondering which Linux Distribution is more suitable for this kind of proyect?. Is there a list of which software i should install?
jameswilson
Post by jameswilson »
well its down to preference. The best supported here is either Coreys CTU zm built in Fedora Core 3 or the mandriva based distro in either live or non live versions. I prefer the non live mandriva 2006 one, but Coreys is fust as good but sets its paths out differently
James Wilson
zoneminder
Site Admin
Post by zoneminder »
If you are happy building from source then most distros should be fine. I develop on Fedora so that is probably best supported (by me) but you'll probably get a faster response to queries from Ross (LiveCD) or Corey (rpms) anyway!
Phil
