Is there a date/time format variable for tenths of a second?
ie %y = year
Tony
date/time format
The best I can do is give you a link to the resources.
http://datetime.perl.org/?Resources
I'll be going through it just because you raised my curiosity. First one to post the answer wins
Cheers,
Corey
Cheers,
Corey
looking here:
http://www.gsp.com/cgi-bin/man.cgi?sect ... te::Format
doesn't seem to show a variable for fractions of a second, and I'm not sure what it is on the link you gave that shows it is possible?
Tony
Tony
- zoneminder
- Site Admin
- Contact:
There is no format specifier for this, as the time that is passed into the date functions (and the time in perl, Linux in general) only has 1 second precision. ZM uses some tricks internally to be more precise but it's all a bit of a hack. I may be able to fake fractional seconds but it's not as trivial as just putting in a different format spec I'm afraid.
Phil
Thanks, someone was asking if zm could be used to find the speed of a vehicle as it passed the camera, I thought of counting the frames but the frame speed seems to build up to the target speed over a short time so the other way i thought of was to count the tenths of a second over a set distance.
Tony
Tony
i think the only way to do this is to have a special motion detector with 2 points that calculates the speed of the target. It would need to be a big targhet mind, ie a zoomed in view. But im afraid i dont know how i just suggested it a few months back.
James Wilson
- zoneminder
- Site Admin
- Contact:
