I've just install zm on ubuntu, and it starts well. So i try to setup my Philips PCVC740K webcam and the device stay red in the main page.
I have update shared memory value
I have no screen/keyboard on my server and i don't know how to check if my webcam run well.
lsusb
Bus 001 Device 003: ID 0471:0311 Philips PCVC740K ToUcam Pro [pwc]
### v4l2 device info [/dev/video1] ###
general info
VIDIOC_QUERYCAP
driver : "pwc"
card : "Philips 740 webcam"
bus_info : "usb-0000:00:1f.2-1"
version : 10.0.7
capabilities : 0x5000001 [VIDEO_CAPTURE,READWRITE,STREAMING]
standards
inputs
VIDIOC_ENUMINPUT(0)
index : 0
type : unknown
audioset : 0
tuner : 0
std : 0x0 []
status : 0x0 []
video capture
VIDIOC_ENUM_FMT(0,VIDEO_CAPTURE)
index : 0
type : VIDEO_CAPTURE
flags : 1
description : "Raw Philips Webcam"
pixelformat : 0x32435750 [PWC2]
VIDIOC_ENUM_FMT(1,VIDEO_CAPTURE)
index : 0
flags : 0
description : "4:2:0, planar, Y-Cb-Cr"
pixelformat : 0x32315559 [YU12]
VIDIOC_G_FMT(VIDEO_CAPTURE)
fmt.pix.width : 320
fmt.pix.height : 240
fmt.pix.pixelformat : 0x32315559 [YU12]
fmt.pix.field : NONE
fmt.pix.bytesperline : 480
fmt.pix.sizeimage : 115200
fmt.pix.colorspace : unknown
fmt.pix.priv : 0
controls
VIDIOC_QUERYCTRL(BASE+0)
type : INTEGER
minimum : 0
maximum : 128
step : 1
default_value : 0
flags : 0
VIDIOC_QUERYCTRL(BASE+1)
type : INTEGER
minimum : 0
maximum : 64
step : 1
default_value : 0
flags : 0
VIDIOC_QUERYCTRL(BASE+2)
type : INTEGER
minimum : -100
maximum : 100
step : 1
default_value : 0
flags : 0
### video4linux device info [/dev/video1] ###
general info
VIDIOCGCAP
name : "Philips 740 webcam"
type : 0x1 [CAPTURE]
channels : 1
audios : 1
maxwidth : 640
maxheight : 480
minwidth : 160
minheight : 120
channels
VIDIOCGCHAN(0)
channel : 0
tuners : 0
flags : 0x0 []
type : CAMERA
norm : 0
tuner
ioctl VIDIOCGTUNER: Invalid argument
audio
VIDIOCGAUDIO
audio : -1
volume : 0
bass : 0
treble : 0
VIDIOCGPICT
brightness : 24064
hue : 65535
colour : 65468
contrast : 64512
whiteness : 63488
depth : 24
palette : YUV420P
buffer
VIDIOCGFBUF
base : (nil)
height : 0
width : 0
depth : 0
bytesperline : 0
window
VIDIOCGWIN
x : 0
y : 0
width : 320
height : 240
chromakey : 0
flags : 655360
Nov 9 00:41:08 vdrbox zmpkg[9998]: INF [Command: start]
Nov 9 00:41:09 vdrbox zmdc[10010]: INF [Server starting at 06/11/09 00:41:09]
Nov 9 00:41:12 vdrbox zmdc[10033]: INF ['zmc -d /dev/video' started at 06/11/09 00:41:12]
Nov 9 00:41:12 vdrbox zmdc[10010]: INF ['zmc -d /dev/video' starting at 06/11/09 00:41:12, pid = 10033]
Nov 9 00:41:12 vdrbox zmc_dvideo[10033]: INF [Debug Level = 0, Debug Log = <none>]
Nov 9 00:41:12 vdrbox kernel: [17225304.596000] pwc set_video_mode(320x240 @ 10, palette 15).
Nov 9 00:41:12 vdrbox kernel: [17225304.596000] pwc decode_size = 3.
Nov 9 00:41:12 vdrbox kernel: [17225304.596000] pwc Using alternate setting 3.
Nov 9 00:41:12 vdrbox kernel: [17225304.736000] pwc frame_size=44160, vframes=10, vsize=3, vsnapshot=0, vbandlength=736
Nov 9 00:41:13 vdrbox kernel: [17225304.808000] pwc set_video_mode(160x120 @ 10, palette 15).
Nov 9 00:41:13 vdrbox kernel: [17225304.808000] pwc decode_size = 1.
Nov 9 00:41:13 vdrbox kernel: [17225304.808000] pwc Using alternate setting 1.
Nov 9 00:41:13 vdrbox kernel: [17225304.960000] pwc frame_size=18900, vframes=10, vsize=1, vsnapshot=0, vbandlength=630
Nov 9 00:41:13 vdrbox zmc_dvideo[10033]: ERR [Failed to get camera source: Invalid argument]Nov 9 00:41:13 vdrbox zmdc[10010]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Nov 9 00:41:13 vdrbox zmdc[10010]: INF [Starting pending process, zmc -d /dev/video]
Nov 9 00:41:13 vdrbox zmdc[10037]: INF ['zmc -d /dev/video' started at 06/11/09 00:41:13]
Nov 9 00:41:13 vdrbox zmdc[10010]: INF ['zmc -d /dev/video' starting at 06/11/09 00:41:13, pid = 10037]
Nov 9 00:41:13 vdrbox zmc_dvideo[10037]: INF [Debug Level = 0, Debug Log = <none>]
Nov 9 00:41:13 vdrbox kernel: [17225305.036000] pwc set_video_mode(160x120 @ 10, palette 15).
Nov 9 00:41:13 vdrbox kernel: [17225305.036000] pwc decode_size = 1.
Nov 9 00:41:13 vdrbox kernel: [17225305.036000] pwc Using alternate setting 1.
Nov 9 00:41:13 vdrbox kernel: [17225305.176000] pwc frame_size=18900, vframes=10, vsize=1, vsnapshot=0, vbandlength=630
Nov 9 00:41:13 vdrbox zmc_dvideo[10037]: ERR [Failed to get camera source: Invalid argument]Nov 9 00:41:13 vdrbox zmdc[10010]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Nov 9 00:41:13 vdrbox zmdc[10039]: INF ['zmfilter.pl' started at 06/11/09 00:41:13]
Nov 9 00:41:13 vdrbox zmdc[10010]: INF ['zmfilter.pl' starting at 06/11/09 00:41:13, pid = 10039]
Nov 9 00:41:14 vdrbox zmfilter[10039]: INF [Scanning for events]
Nov 9 00:41:14 vdrbox zmdc[10010]: INF ['zmaudit.pl -c' starting at 06/11/09 00:41:14, pid = 10044]
Nov 9 00:41:14 vdrbox zmdc[10044]: INF ['zmaudit.pl -c' started at 06/11/09 00:41:14]
Nov 9 00:41:16 vdrbox zmdc[10049]: INF ['zmwatch.pl' started at 06/11/09 00:41:16]
Nov 9 00:41:16 vdrbox zmdc[10010]: INF ['zmwatch.pl' starting at 06/11/09 00:41:16, pid = 10049]
Nov 9 00:41:16 vdrbox zmwatch[10049]: INF [Watchdog starting]
Nov 9 00:41:16 vdrbox zmwatch[10049]: INF [Watchdog pausing for 30 seconds]
Nov 9 00:41:17 vdrbox zmdc[10053]: INF ['zmupdate.pl -c' started at 06/11/09 00:41:17]
Nov 9 00:41:17 vdrbox zmdc[10010]: INF ['zmupdate.pl -c' starting at 06/11/09 00:41:17, pid = 10053]
Nov 9 00:41:18 vdrbox zmdc[10010]: INF [Starting pending process, zmc -d /dev/video]
Nov 9 00:41:18 vdrbox zmdc[10010]: INF ['zmc -d /dev/video' starting at 06/11/09 00:41:18, pid = 10055]
Nov 9 00:41:18 vdrbox zmdc[10055]: INF ['zmc -d /dev/video' started at 06/11/09 00:41:18]
Nov 9 00:41:18 vdrbox zmc_dvideo[10055]: INF [Debug Level = 0, Debug Log = <none>]
Nov 9 00:41:18 vdrbox Update agent starting at 06/11/09 00:41:18
Nov 9 00:41:18 vdrbox kernel: [17225309.868000] pwc set_video_mode(160x120 @ 10, palette 15).
Nov 9 00:41:18 vdrbox kernel: [17225309.868000] pwc decode_size = 1.
Nov 9 00:41:18 vdrbox kernel: [17225309.868000] pwc Using alternate setting 1.
Nov 9 00:41:18 vdrbox zmc_dvideo[10055]: ERR [Failed to get camera source: Invalid argument]Nov 9 00:41:18 vdrbox kernel: [17225310.012000] pwc frame_size=18900, vframes=10, vsize=1, vsnapshot=0, vbandlength=630
Nov 9 00:41:18 vdrbox zmdc[10010]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
Nov 9 00:41:28 vdrbox zmdc[10010]: INF [Starting pending process, zmc -d /dev/video]
Nov 9 00:41:28 vdrbox zmdc[10066]: INF ['zmc -d /dev/video' started at 06/11/09 00:41:28]
Nov 9 00:41:28 vdrbox zmdc[10010]: INF ['zmc -d /dev/video' starting at 06/11/09 00:41:28, pid = 10066]
Nov 9 00:41:28 vdrbox zmc_dvideo[10066]: INF [Debug Level = 0, Debug Log = <none>]
Nov 9 00:41:28 vdrbox kernel: [17225319.832000] pwc set_video_mode(160x120 @ 10, palette 15).
Nov 9 00:41:28 vdrbox kernel: [17225319.832000] pwc decode_size = 1.
Nov 9 00:41:28 vdrbox kernel: [17225319.836000] pwc Using alternate setting 1.
Nov 9 00:41:28 vdrbox kernel: [17225319.976000] pwc frame_size=18900, vframes=10, vsize=1, vsnapshot=0, vbandlength=630
Nov 9 00:41:28 vdrbox zmc_dvideo[10066]: ERR [Failed to get camera source: Invalid argument]Nov 9 00:41:28 vdrbox zmdc[10010]: ERR ['zmc -d /dev/video' exited abnormally, exit status 255]
I haven't log in /var/log for zm ?
