I have:
Debian Etch
PHP 5
MySQL 5
Apache 2
ZM 1.22.3
AXIS 206
It took me two days to configure everything until the ZM is working and the console shows the "Running" status.
Then I got to a point where everything looked good but when I opened the Monitor to check the image comming from the camera there it showed a broken link image icon
I thought I did something wrong as I did a thousand changes in the configuration to get ZM running, so I decided to start from scratch.
I installed everthing from 0: Debina Etch, Apache2, Mysql5, PHP5, compile ZM, etc.
Now it took me just a couple of hours for everything, but the result is exactly the same... there's a broken link image icon showing all the time.
I have checked that my camera is generating jpg images and it does under xxx.xxx.xxx/axis-cgi/jpg/image.cgi?resolution=160x120
The host username and password format is username:password@IP
Moreover, if I click on the Zones column link that does show the image!!!
Any Idea?
