I am new to linux and also to ZM. Can anyone suggest me how can I get ZM running? My server has 2 Dual Core Intel CPUs, 4GB RAM, 640GB harddrive. Currently I have FC5 installed on this server. I have downloaded ZMLiveCD_1.22.2.1.iso. How can I proceed in this case?
Thank you in advance.
hrparikh
How to use ZMLiveCD_1.22.2.1 ?
i hav eanswered your other post please dont double post
James Wilson
boot cd
whan at desktop click on install button
progress through the questions, when it comes to partitions then i do
4 gig /
1.6gig swap
the rest of the disk as /var
follow through the install choices and that should be it, any questions post here
4 gig /
1.6gig swap
James Wilson
hi James,
After I downloaded ZM1.22.2.1_livecd.iso, I burned a bootable disk with this. I have fedora core 5 installed on the server. When I insert this bootable disk and boot the server using this disk, it does not show any GUI. It goes to a command prompt (similar to DOS in windows). I can see the folders in the disk when I use 'dir' but can not do anything else. Please let me know if I am doing something wrong or if I should use some other version of ZM.
it would appear your gfx card isnt detected
what is it
you will have to pass some boot options like vga=771
or vgadrv=vesa
one thing to try when you get the prompt log in as
root
root
and enter
start x
then report the errors
what is it
or vgadrv=vesa
root
root
and enter
start x
James Wilson
