I believe that someone should have ported the zonemider application to some embedded boards. I would be greatful if someone can give your feedback regarding embedded boards. If so, can anyone of you please suggest me the board details, cpu usage for zoneminder, harddisk support, ffmpeg support and other configurations? Awaiting your valuable ideas and inputs.
thanks in advance
Johnson
It's nothing concrete but I'm sure I recall someone saying they had run ZM on an Arm system. I do a bunch of work on Arm systems but have never actually tried using ZM on them but you may find the posts if you search for arm.
