Hi!
I have a problem with the card in subject.
When I'm setting monitor properties in ZM I note tha when I set one monitor with NTSC or PAL this create problem for other monitor, it seems that monitor aren't indipendents... it's right this? 8-/
Do you know that this card works correctly with 4 monitors in PAL mode?
I'm using ZM 1.22.0, coulde be that there was a bug in this version regardling this? Could I have to update to ZM 1.22.3?
Thanks,
Alex
GrandTec XGUARD PCI CARD Problem
- zoneminder
- Site Admin
- Contact:
