Hi there,
I have the saa7134 competible card installed. It used to work with Zoneminder; after I upgrade to FC5/ZM 1.2.3; the ZM only display grey color image.
I would like to know how to add option to a module when it load to kernel.
I try insmod saa7134 card=2, for example. but it seems did not work.
The following are the dmesg output ..
saa7130[0]: found at 0000:02:00.0, rev: 1, irq: 20, latency: 32, mmio: 0xec000000
saa7134: <rant>
saa7134: Congratulations! Your TV card vendor saved a few
saa7134: cents for a eeprom, thus your pci board has no
saa7134: subsystem ID and I can't identify it automatically
saa7134: </rant>
saa7134: I feel better now. Ok, here are the good news:
saa7134: You can use the card=<nr> insmod option to specify
saa7134: which board do you have. The list:
saa7134: card=0 -> UNKNOWN/GENERIC
saa7134: card=1 -> Proteus Pro [philips reference design] 1131:2001 1131:2001
saa7134: card=2 -> LifeView FlyVIDEO3000 5168:0138 4e42:0138
saa7134: card=3 -> LifeView/Typhoon FlyVIDEO2000 5168:0138 4e42:0138
saa7134: card=4 -> EMPRESS 1131:6752
saa7134: card=5 -> SKNet Monster TV 1131:4e85
saa7134: card=6 -> Tevion MD 9717
saa7134: card=7 -> KNC One TV-Station RDS / Typhoon TV Tune 1131:fe01 1894:fe01
saa7134: card=8 -> Terratec Cinergy 400 TV 153b:1142
saa7134: card=9 -> Medion 5044
saa7134: card=10 -> Kworld/KuroutoShikou SAA7130-TVPCI
saa7134: card=11 -> Terratec Cinergy 600 TV 153b:1143
saa7134: card=12 -> Medion 7134 16be:0003
saa7134: card=13 -> Typhoon TV+Radio 90031
saa7134: card=14 -> ELSA EX-VISION 300TV 1048:226b
saa7130[0]: subsystem: 1131:0000, board: UNKNOWN/GENERIC [card=0,autodetected]
saa7130[0]: board init: gpio is 3d0000
How to add option to kernel modules when it load
- zoneminder
- Site Admin
- Contact:
Normally you can add options in /etc/modprobe.conf, so in your case add a a line like to it.
options saa7134 card=2
Phil
