IQeye700 Network Cameras
bjs
Post by bjs »
Hi.
Soon ive got one of thes camra in reach for testing with zm, is it known to work?
jameswilson
Post by jameswilson »
i tested one but failed but it is beleived to work yes
James Wilson
bjs
Post by bjs »
jameswilson wrote:i tested one but failed but it is beleived to work yes
oh, how great, thanks for the reply!
bjs
Post by bjs »
Hi finaly ive got the cam,
ive got it to work in the network, browsing the camera in the new with http://ip/now.jpg works prefect, i just cant get ZM to grab the pic.
my settings are
Monitor Iqeye
Type : Remote
Host : 192.168.1.200
Port : 80
Path : /now.jpg
Width : 512
Height : 384
Thats what i change, should i change someting more?
Zm is 1.22.2
jameswilson
id try 1.22.3 as this is better with ip cameras
James Wilson
bjs
Post by bjs »
okay, ill try that today... got some time now.. :D
bjs
Post by bjs »
like a GLOVE!
works prefect so fare, just testing now, low pic size 256*192 i had to upgrade then it workt.
ill try to capture the lagerst image now.. 2048*1536
Have i nice day, i will! :D
:wink:
jameswilson
you will probably run into a shared mem linit on the higher res's if so check you logs to confirm
James Wilson
bjs
Post by bjs »
yeah the machine died with a higer res, its only a 1Ghz can, so im planinge to get a new one, what should i think about when i construct the new can?
bjs
Post by bjs »
it works like a charm now..
Calibrating delay using timer specific routine.. 4810.35 BogoMIPS (lpj=9620710)
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 512K (64 bytes/line)
AMD Athlon(tm) 64 X2 Dual Core Processor 4600+ stepping 02
using 3 segate Model: ST3250624AS in a software raid.
mobo is Asus M2NPV-vm bord with 2gb ram on.
and gfx is MSI NX7300GS
Dist is http://cdimage.debian.org/cdimage/etch_ ... etinst.iso
just installed zm bye the installations instuctions , had wrong password but after fixing that it works lika hell..
now i want to use the zm to just take stills at alarm, and show it on a LCD like 50" or so..
